rattling noise inside exhaust? - Ford Truck Enthusiasts Forums
Old 02-12-2009, 06:37 AM
RUSTANG67 RUSTANG67 is offline
RUSTANG67 is starting off with a positive reputation.
This is kinda an update on a previous post:
http://www.ford-trucks.com/forums/81...e-pinging.html
Last weekend went for a ride in the truck and it's not detonation but a loud rattling noise coming from under the truck. it usually only appears during light to moderate acceleration. I crawled around underneath suspecting a loose heat shield or something, but everything appears tight.
I then took a rubber mallet and beat on the exhaust. I could hear a slight rattling when I banged it close to the passenger side catalyst. Is it likely the catalyst media's came loose?
Old 02-12-2009, 06:43 AM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Sounds like you have a cat or two going bad. That sound is likely your broken up catalytic media rattling around in there...
Old 02-12-2009, 08:08 AM
Is that a common occurance?
Old 02-12-2009, 10:01 AM
Tylus's Avatar
Tylus Tylus is online now
Submarines Once....
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
not really...but stuff happens.
take it to Ford. You have a 8 year emissions warranty. If it is a bad cat or 2, they should fix for free under that Federal Emissions Warranty
Old 02-12-2009, 10:37 AM
Catmonkey Catmonkey is offline
Catmonkey is starting off with a positive reputation.
Bear in mind when they do fail, it's usually a symptom of something else that caused it.
Old 02-18-2009, 09:39 PM
tazz3369 tazz3369 is offline
tazz3369 is starting off with a positive reputation.
i had a garage do the same with my 2004 f150 4wd and it turened out to be the 4wd hub seal a quick test is put it in 4wd and if the noise stops then it is the vacum in the 4wd hub but it was the same thing garage told me at first was cat so i said why would it not do it in 4wd as well then and yes not using that garage any more
Old 02-19-2009, 09:35 AM
DaMole's Avatar
DaMole DaMole is offline
DaMole has a very good reputation on FTE.DaMole has a very good reputation on FTE.DaMole has a very good reputation on FTE.
We had one go bad in one of the F150 work trucks. It is not a common problem but like said stuff happens.
Old 03-03-2009, 08:29 PM
brian noyes brian noyes is offline
brian noyes is starting off with a positive reputation.
did the hub seal fix this ? is it a similar seal used on the f350 4x4 trucks? i have the exact same problem on my 04 f150 4x4 61k miles and i was thinking transmission
Old 03-03-2009, 08:46 PM
hub seal
my boss has 04 harley f-150 4x4 his was on seal i am going to check my vacum on the lines first should be holding 20 lbs the new solenoid i picked up the updated one was 27 dollars cdn a quick test is put it in 4 wheel and if the grinding goes away it means it is either the solinoid or your seals wich are right behind your knuckles the solinoid is on the firewall right behind your battery with the two lines attached
Old 03-03-2009, 09:02 PM
Drizzt's Avatar
Drizzt Drizzt is offline
Drizzt is gaining momentum as a positive member of FTE.
yep if its not just a heat shield aroudn one of the cats its probably the cat itself. happened to me on my last f150. it was pretty high mileage though so somewhat expected
Old 04-07-2009, 02:45 PM
damone damone is offline
damone is starting off with a positive reputation.
I had same sound during accell only. All exhaust components were tight, but when under accell one of the heat shileds would come into contact with another part and the resonance (rattle) would appear.
The dealer fixed by welding heat shiled "up out of way" of contact area. This of course put undue stress on the exhaust and I developed a leak (just a week after rattle fix). Of course the dealer didn't admit that the cause was there welding the heat shield "up out of the way", but none the less the leak and rattle are still gone after a year and 10K-mi.
Old 05-21-2009, 12:07 AM
tippmann87's Avatar
tippmann87 tippmann87 is offline
tippmann87 is starting off with a positive reputation.
Can someone better explain the sound? I'm having a similar problem with my truck. On moderate acceleration I hear a rattling type sound that seems to be coming from the engine. It is hard to explain, but almost sounds like if you took BB's and put them in a thick metal pot and shook it. It's not very loud though, it's most noticable when you are driving along jersey walls b/c you can hear it echo off the wall. I only notice it when the windows are down.......
Check Engine Light on Today - Catalyst System Efficiency BGLeRoy Modular V10 (6.8l) 12 05-01-2015 10:37 AM
Inspection plate rattle GONE truckfella Modular V10 (6.8l) 4 10-25-2013 05:45 AM
Ford Explorer 2008 V6 -When to change catalyst converter assembly atifzaman Explorer, Sport Trac, Mountaineer & Aviator 3 10-07-2012 10:47 AM
Mysterious "Rattle" Noise Underneath 302 Engine Rick_Fury General Automotive Discussion 2 05-06-2011 09:12 PM
Engine Rattle Noise? Rick_Fury 1973 - 1979 F-100 & Larger F-Series Trucks 15 02-20-2011 07:43 PM
Tags
05, 2004, 2005, 99, acceleration, edge, exhaust, f150, ford, heat, makes, noise, rattle, rattling, shield
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
