Spray On Bedliner Removal
Old 03-21-2009, 06:31 PM
uofmgriz's Avatar
uofmgriz
uofmgriz is offline
My spray on bedliner has some chunks that have been knocked out of it over time, and I'm thinking about pulling it out and having it redone. Any suggestions on getting the old out without completely destroying the bed? Would it be more cost effective to take it to a shop and let them deal with it? Your advice is appreciated!!
Old 03-21-2009, 06:36 PM
69cj's Avatar
69cj
69cj is offline
Who did the bedliner?? They would be the experts. The two biggies here, Linex and Rhino, give lifetime warranties.
Old 03-21-2009, 07:18 PM
BPofMD's Avatar
BPofMD
BPofMD is online now
Received 1,097 Likes on 997 Posts
Agreed with ^ ... Free is always good!
Old 03-21-2009, 07:58 PM
uofmgriz's Avatar
uofmgriz
uofmgriz is offline
dunno...was already in the truck when I bought it, no paperwork on it.
Old 03-21-2009, 08:10 PM
04F-250mark's Avatar
04F-250mark
04F-250mark is offline
Same here anyone got a answer?I've got chuncks out of mine and was wandering the same thing!!
Old 03-21-2009, 08:14 PM
Sarge261's Avatar
Sarge261
Sarge261 is offline
One of the easiest ways to tell what you have is...the Rhino liner has actual large chunks in the texture itself. The Line-X is finely textured, comparitively speaking, and usually they stick a little badge in the corner of the bed.
Hope this helps, I would take a picture of mine for ya but I have a black truck and the bed liner would be hard to see.
Sarge
Old 03-21-2009, 08:51 PM
uofmgriz's Avatar
uofmgriz
uofmgriz is offline
Sarge
Part of the problem is there are so many different liners out on the market today, it could easily have either of the textures, but not necessarily reflect that particular brand inwhich you've listed. Sort of a catch 22 if you will. I don't know if I should use like a heat gun and soften (or try to) and basically peel it like a banana or are there other alternative methods?
Old 03-21-2009, 09:04 PM
liv's Avatar
liv
liv is offline
If you take it to someone they can just patch it for you. No need to pull all of it out just to redo it. Should cost less than $50 for little stuff.
The company that did mine went under so I just took it to a line-x shop and they patched up the pieces that were pealing/scratched. Looks great and cost $30
Old 03-21-2009, 09:05 PM
04F-250mark
Mine is a Rhino and I have the tag inthe bed and I just want to know if it is a lifetime warranty for the truck or what?
Old 03-21-2009, 09:07 PM
liv's Avatar
liv
liv is offline
Yep lifetime warranty no matter who/where you bought it from or take it too.
Make sure and call and setup an appointment. They don't like it when you just show up and tell them you want free work done.
Sarge261's Avatar
Sarge261
Sarge261 is offline
^^^ Yes I believe it is, however some of the manufactuers will only offer this to the original owner.
Old 03-21-2009, 09:13 PM
04F-250mark
That is cool as you know what i've got some spots that i've sealed up with sikaflex,now I know if I can find a place it will get fixed! Thanks fella's
