How do I remove the headlight switch knob??? - Page 2 - Ford Truck Enthusiasts Forums
Old 09-17-2011, 12:12 PM
GLR's Avatar
GLR GLR is offline
GLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputation
The resistor that sometimes goes bad is the larger white "disc" about in the middle of the switch. Thanks for the pic Montana.
Old 09-18-2011, 01:49 AM
Alvin in AZ's Avatar
Alvin in AZ Alvin in AZ is offline
Alvin in AZ is gaining momentum as a positive member of FTE.Alvin in AZ is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by montana_highboy View Post
For future reference, depress button depicted below
Oooo... good picture, Montana! :)
I changed the file name on mine and also I scanned mine with
a borrowed scanner that just can never be as good as my old
"industrial" HP 4c...
http://www.panix.com/~alvinj/file12/switch.jpg
The nut is easy to remove with the right tool...
http://www.panix.com/~alvinj/file12/switchtool.jpg
And a picture of the headlight **** and stem and windshield
wiper's ****-clip that needs to be pulled at the same time...
http://www.panix.com/~alvinj/file12/coverhardware.jpg
Pull on that clip with a cotter pin puller...
http://www.panix.com/~alvinj/file12/cotterpin.jpg
Alvin in AZ
Old 09-18-2011, 08:00 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by Holiver31 View Post
if replacing the bulbs dont work you may try cleaning the connections on the back of the gauge panel with some rubbing alcohol since they are notorious for becoming corroded.
However basically the whole back of the panel is one giant printed circuit board.
If the cluster back is crumbling you may want to look into finding another gauge cluster or building your own.
There's no need to "build your own" because 1981/91 Econolines use the same cluster back (and printed circuit) as 1976/79 F100/350's, 1978/79 Bronco's with Oil/Amp guages.
1976/79 F100/350's, 1976/80 Econolines & 1978/79 Bronco's used cluster backs made from a composition material that can TURN TO DUST before your very eyes!
In 1981, Ford came out with hard plastic cluster backs, these replaced the crap originals. Some of the originals were replaced, some were not.
E1PZ-10848-A .. Cluster Back-Use with Oil/Amp Gauges / Obsolete
Applications: 1976/79 F100/350 / 1976/91 Econoline / 1978/79 Bronco.
E1PZ-10848-B .. Cluster Back-Use with Oil/Amp Warning Lights / Obsolete
Applications: 1976/79 F100/350 / 1976/86 Econoline / 1978/79 Bronco.
D6TZ-10K843-B .. Printed Circuit Board-Use with Oil/Amp Gauges / Obsolete
Old 08-09-2012, 05:56 AM
palsims palsims is offline
palsims is starting off with a positive reputation.
Dear Sir,
Where would I be able to purchase a headlight switch and cluster back for my 1979 f150 4x4? My dim is bright and bright is dim and turn signal operates brake light in dash!! All messed up.
Old 08-09-2012, 12:25 PM
Quote:
Originally Posted by palsims View Post
Where would I be able to purchase a headlight switch and cluster back for my 1979 F150 4x4? My dim is bright and bright is dim and turn signal operates brake light in dash!! All messed up.
Welcome to FTE
There are TWO different cluster backs, they do not interchange!
Does your truck have Oil & Amp gauges (E1PZ-10848-A) or Oil & Amp warning lamps (E1PZ-10848-B)?
CARPENTER NOS OBSOLETE PARTS in Concord NC has 519 of E1PZ-10848-A and 84 of E1PZ-10848-B = 800-476-9653.
You can buy the headlamp switch at any autoparts store.
D3AZ-11654-A .. Headlamp Switch (Motorcraft SW-1226).
Applications: 1978/79 F100/350, Bronco & Econoline // 1973 Mustang/Cougar / 1973/74 Galaxie/LTD / 1973/76 Torino/Ranchero / 1973/77 Maverick/Comet / 1974/76 Cougar.
1974/78 Mustang II / 1974/80 Pinto/Bobcat / 1975/78 LTD without hidden headlamps / 1975/80 Granada/Monarch / 1977/80 Lincoln Versailles.
Old 08-09-2012, 05:14 PM
81-F-150-Explorer 81-F-150-Explorer is offline
81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold
Quote:
The large white disc is the heat insulator.
The variable resistor for the instrument lights is a part of the white disc, as the metal spring looking circut.
The thermal circut breaker is on the other side of the white disc. If the current draw exceeds the rated limit for the switch, due to a short circut, the excessive heat passing through the white insulator will cause the circut breaker to open, shutting off the headlamps. When it cools back down the lights will come back on. This sometimes happens in quick succession. It is sometimes triggered by upgrading headlamps to halogens due to the rise in amperage needed to run halogens.
The circut breaker also has a limited life span. It's basically a spring that heats up to cut the connection. When it wears out, it will also cause the headlamps to cycle on and off.
Dear Sir,
It sounds like someone swapped the cluster out on you, with the incorrect printed circut. Perhaps the original suffered from cluster rot, and they found any old one to stick in there.
Check the number on the back of the printed circut and post it.
I'm guessing it's from the wrong year for your truck. A new cluster back won't fix the problems you describe, that will only fix cluster rot, but the correct printed circut might.
Old 09-03-2012, 07:10 PM
cybercrone cybercrone is offline
cybercrone is starting off with a positive reputation.
Just thanks....
You guys are indeed awesome. I took down my steering post a few years ago to replace ignition module (1986 F-150 stepside) and had a helluva time doing it, got stuck right at the start because I couldn't figure out how to get ***** off the headlights and wiper switches. I thought I wrote up notes at the time but couldn't find them today and couldn't remember a thing. You saved me a lot of time!
I'm gonna get stuck again because I can't remember how to lower the steering post, so I'll be back!
Old 11-12-2012, 06:41 PM
benbuilder's Avatar
benbuilder benbuilder is online now
benbuilder is starting off with a positive reputation.
dimmer switch
I have depressed that button in the past and had no problem. Tonight I tyried it for 15 minutes and it will not come out. Any ideas?
Old 07-21-2013, 10:46 PM
MTmtntinkeringagain MTmtntinkeringagain is offline
MTmtntinkeringagain is starting off with a positive reputation.
Thanks for the great photo and help. Just found a hot wire to carb. Have had a fire due to PO, so now that finding the hot, starter keeps turning, Batt *obviously* losing power, appreciate the help so can get behind plastic instrument panel...... correct whatever ELSE PO did. I'm a rookie, so FTE is a blessing to us who's Messin' w/old Fords
Old 07-22-2013, 12:40 AM
77&79F250's Avatar
77&79F250 77&79F250 is offline
Used OEM parts guy
77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future
Quote:
1. disconnect the battery
2. find the button and be ready to push it down
3. lightly push and pull on the light switch ****, that might help the button go down.
At least that the trick that works for me.
Old 08-24-2013, 10:46 PM
notthemaniusedtobe's Avatar
notthemaniusedtobe notthemaniusedtobe is offline
notthemaniusedtobe is starting off with a positive reputation.
This is an absolutely perfect picture of the switch in question. Mine was upside-down compared to the pic, so I made damn sure to turn it the other way for ease of ****-removal in future, thanks for inspiring a great idea!
Old 07-13-2014, 04:05 PM
itzsnitz itzsnitz is offline
itzsnitz is starting off with a positive reputation.
Switch Replacement/Upgrade
Has anyone seen an upgrade for this switch? I don't care for the durability issues and I'm thinking about swapping in hard switches instead.
  #28
Old 10-08-2014, 02:55 PM
buckeyeinatl buckeyeinatl is offline
buckeyeinatl is starting off with a positive reputation.
Just for anyone new and who doesn't already have their dash all apart to get to this switch, you don't have to disassemble any of the dash. Just follow the instructions to pop out the **** shaft, unscrew the nut holding it to the dash and it falls inward a little, and there is just barely enough slack in the wires that you can separate the wiring harness from the switch itself. I just did it myself - and I'm a newbie. LOL.
  #29
Old 07-12-2015, 07:52 PM
1974highboy 1974highboy is offline
1974highboy is starting off with a positive reputation.
Can you please explain how you got the whole assembly out? I can't seem to get mine out
Thanks
Wiper switch knob Ripemdry 1973 - 1979 F-100 & Larger F-Series Trucks 17 02-26-2016 11:42 AM
'93 headlight button removal bf5113x 1987 - 1996 F150 & Larger F-Series Trucks 5 01-15-2016 05:58 PM
headlight switch knob removal Bird-Dog 250 1999 to 2016 Super Duty 7 09-13-2015 01:11 PM
Removing the Headlight knob insideout414 1987 - 1996 F150 & Larger F-Series Trucks 16 03-08-2013 02:14 AM
Light and Wiper knob removal problem. ToughestTruckBuilt 1973 - 1979 F-100 & Larger F-Series Trucks 10 07-24-2009 01:50 PM
Tags
06, 100, 1974, 1976, 78, f150, f250, ford, headlight, hook, knob, pull, ranger, removal, remove, switch, tool
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
