V10 Oil Filter - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
V10 Oil Filter
Old 02-11-2009, 05:59 PM
rudedogii's Avatar
rudedogii rudedogii is offline
rudedogii is starting off with a positive reputation.
V10 Oil Filter
This is for you V10 owners. Doses anybody know if the stock filter can be interchanged to a bigger filter? Right now I use the Fram PH2. Thats a small filter for such a big engine.
I got room for a bigger filter. I tried the Fram PH8 but the threads are different.
Old 02-12-2009, 12:54 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Dunno if they make one that'll work. Bypass pressure is also crucial, so don't forget to check on that if you're playing around
ALSO - the PH2 does not have a silicone anti-drainback valve. You should be using the TG2 or XG2.
One thought comes to mind, that you can buy a remote-filter setup for a 4.6L/5.4L and it should mount onto the V10's oil filter adapter. That way, you could hookup whatever oil filter adapter you want, but it would have to be in a remote location. Then you could use the HP2 filter...
WARNING - no Fram bashing.
Old 02-12-2009, 01:10 PM
bubbasz1's Avatar
bubbasz1 bubbasz1 is offline
bubbasz1 has a very good reputation on FTE.bubbasz1 has a very good reputation on FTE.bubbasz1 has a very good reputation on FTE.
Wix offers a nice long one, I'll look later and see if I have one in the garage to get the part number off it.
Monsta's Avatar
Monsta Monsta is offline
Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.
Use a Motorcraft filters FL-820S.
Last edited by Krewat; 02-12-2009 at 01:29 PM. Reason: Removed Fram comments - again, NO FRAM BASHING
Old 02-12-2009, 07:45 PM
shorebird's Avatar
shorebird shorebird is offline
shorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputation
Quote:
X2
Aww..... Krewat You spoiled the fun;
"WARNING - no Fram bashing."
Old 02-12-2009, 08:01 PM
patrickke's Avatar
patrickke patrickke is offline
patrickke is starting off with a positive reputation.
just a bit curious why no fram bashing?
Old 02-12-2009, 08:27 PM
rudedogii's Avatar
I will look up that Motocraft part number.
Old 02-12-2009, 08:37 PM
rudedogii's Avatar
That Motocraft filter is the same size as the Fram.
Old 02-12-2009, 08:38 PM
genovet's Avatar
genovet genovet is offline
genovet is starting off with a positive reputation.
The quality of Fram oil filters has fallen off a cliff in recent years. Go to google and search on Fram oil filters and you will find many pages dedicated to the poor quality of Fram oil filters. I personally use Motorcraft or any off-brand made by Champion Labs (e.g. Supertech, Penske, etc.).
Old 02-12-2009, 08:40 PM
barrelhorses barrelhorses is offline
barrelhorses is starting off with a positive reputation.
I just did my first oil change this weekend and used the Motorcraft FL-820-S filter, which is the one recommended in the owner's manual. The filter was less than $4.00 at Wally World IIRC.
Old 02-12-2009, 08:41 PM
patrickke's Avatar
thanks i was oblivious...I use motorcraft on my 6.0 but wasn't enlightened about how bad fram filters are
Old 02-12-2009, 09:23 PM
rudedogii's Avatar
I have been doing some research on the web looking for some cross reference numbers for a bigger filter. But havent found anything yet. That filter is metric 22x1.5mm threads.
I did find this web site on oil filters and now I am really confused on which brand to use!
Engine Oil Filter Study
Old 02-12-2009, 09:34 PM
wiingnut's Avatar
wiingnut wiingnut is offline
wiingnut is gaining momentum as a positive member of FTE.
I'm a Motorcraft guy myself.
Old 02-13-2009, 07:09 AM
Krewat's Avatar
Quote:
Because this thread WILL go from "anyone know about a bigger V10 filter" all the way to "Fram is the worst thing in the world".
Which I have YET to see ANYONE PROVE.
There, I said it ... again. You can read up on the cardboard glued end-caps all you want, everyone saying it's a POS, etc. etc. until you're blue in the face. The truth of it is, the pressure is on the outside of the filter media, pressing on those cardboard end-caps. If paper is so bad under pressure, well, I guess the filter media itself will just go up in a puff of dust too
I've used them all my life, many people still do, and yet, I see NOT ONE STATISTIC about how "bad" they are in a fleet environment, how bad Fram's sales are (really Honeywell/Allied Signal), or any other real-world information saying they are so bad that you need to run away.
There, I said it. ALSO - the standard PH2 is not recommended for the V10, as Ford calls for the Motorcraft FL-820S - the "S" standing for silicone anti-drainback valve, which the PH2 doesn't have - the TG2 and XG2 versions do.
Now, back to the original poster's question - Anyone know of a larger filter for the V10 or the rest of the Ford modular engines?
Old 02-14-2009, 07:39 AM
shorebird's Avatar
Here is a solution to your situation. The thread for the filter is M22 x 1.5mm. I've been looking for filters with that spec. and keep coming up with the same size as the FL-820S. BUT there is a solution. You can install a double filter system. Summit has them. Trans-Dapt Performance Products 1227 - Trans-Dapt Performance Remote Oil Filter Relocation Kits - summitracing.com Currently $59.95.
Oversize V-10 Oil Filters lgould Modular V10 (6.8l) 27 10-01-2014 07:00 AM
Best Oil Filter for my 400? berry1234 1973 - 1979 F-100 & Larger F-Series Trucks 47 03-03-2013 08:32 AM
Fram Oil filters 93F250 Modular V10 (6.8l) 50 08-12-2008 10:39 AM
Fram oil filter for 1994 F150 6 cyl? Crenra 1987 - 1996 F150 & Larger F-Series Trucks 30 03-16-2008 06:50 AM
PH8 vs. PH8A oil filter Beanscoot Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 06-10-2007 01:09 AM
Tags
1227, 22x15mm, 46l, dapt, f250, filter, filters, ford, fram, motorcraft, oil, oilfilter, size, thread, threads, trans, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
