Help..200 ford f350 battery cable and alternator(s)
Noticed my cables could use replacing when Both Batteries were dead. Problem is its a Dual battery system with a Pos. Cable thats about 6 feet long. Unk if I have a single or Dual alternator..Would the second one be noticeable? First ones right on the top. Secondly...My battery light stays on even after replacing both batteries but the charge needle (If thats what it is)..Is pretty much in the middle of the 8 and 18. putting it at about 12.5...Can the alternator still be bad or the needle says its good? My questions are...Is alternator bad? Do I have 1 or 2 alternators and where would second one be? If 2 alternators do you do them both?.ALSO...Is that a single battery cable that runs to both batteries on Pos. terminal??????
here is a post with the diagram for dual and single alt set ups
https://www.ford-trucks.com/forums/8...termarket.html
guisepi
04-29-2019 05:01 AM
