Ohio Chapter Join Chapter, Leader: RUNVS
89 ford f250 4x4
Old 02-15-2009, 06:23 PM
jimm136's Avatar
jimm136
jimm136 is offline
89 ford f250 4x4
Need help with my truck . it started when i though i was out of gas (gage dont work ) put gas in it made it 2 more miles quit again put more in a bout 1/2 tank it quit 3 time in a mile. last time it ran. towed it home replaced fuel fillter new coil an cap and roter. it does the same thing it will start for a few seconds then it fires some then nothing. i can hear the pump working also i do have a hole in the filler tube that leaks. but i have driven it that way for months the codes i get are 15 24 67 51 24 67 some were always on. thanks jim
Old 02-15-2009, 08:42 PM
bmuhlbach's Avatar
bmuhlbach
bmuhlbach is offline
I'd say distrutor module auto part stores can test this for you
Old 02-19-2009, 06:10 PM
jimm136's Avatar
jimm136
jimm136 is offline
i tryed again it started reved it to3000 up and down for 45 sec ?. stalled retried couple of times then fired then nonthing . sprayed starting fluid and it will stay running.
after the fillter it pump gas ?
