You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I have some problem with my engine. It runs great. When I take off from a stop it picks up rpms, then drops back to idle for a few seconds. Then it takes off. A couple times it has actually died. I have changed the CPS twice trying to fix the problem. It is full of oil. I pulled the programmer off, and it still does it. I don't know what else to do. I am afraid it will end up at the stealership. Do any of you know a reputable shope around the Conway that is good with diesels?
__________________
Bobby Joe
02 Excursion Limited, 7.3PSD, 6637, Bully Dog Triple Dog
I have been usinf my Bully Dog to read codes. All i come up with is 0603, but I think it was from when I had the programmer on. I thought TPS also, but I didn't know if that would kill the engine or not. Hope someone chimes in soon. I leave for Houston in a week or so. Thanks for the input.
__________________
Bobby Joe
What kind of oil are you using and when was the last time it was changed?
__________________ WANTED: Someone to go back in time with me. You'll get
paid after we getback. Must bring your own weapons.
Safety not guaranteed. I have only done this once before. www.jimkidd.com
The TPS isn't available from Ford separately. You would have to purchase a $125 throttle pedal assembly. The upside of that is the pedal is extremely easy to replace, the downside is the cost trying to fix an unknown problem.
Somewhere up in the diesel forums is a link containing information on how to get a TPS without the rest of the assembly. I'll look for it this evening.
Does the Bully Dog tuner have any diagnostic capabilities besides reading codes? If it does you can pull up the input voltage to the pedal and watch it to see if it falls off when the truck acts up.
How often does it act up like this?
__________________
Scott
His: 01 F-250 Lariat, 7.3, ZF-6, NV271. A few mods
Hers: 06 Freestar SEL 4.2l
79 Bronco Ranger XLT.. used be the driver, now waiting to become the project.
96 Grand Marquis LS... 25 mpg commuter
Once you get it going down the road does it do ok?
Also, when you look up at the pedal does it have two plugs with separate throttle position and idle validation switches, or is it the combo switch with the single plug?
__________________
Scott
yes, it fine once you get going. It will scream on the interstate and never miss a lick. I am not sure about the pedal, I will have to check into it in the morning.
__________________
Bobby Joe
So where do we stand on this now? I haven't found the switch thread yet....there are about a gazillion hits for the TPS.
__________________
Scott
I pulled the pedal assembly out and cleaned everything with contact cleaner. No help. I spoke with a diesel mechanic at the local stealership, saw him at the local four wheeler shop. He said it sounds like the fuel pump.
__________________
Bobby Joe
