You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Here is a link to a thread on another forum discussing issues with contaminated WVO. The main point of this thread is not to diss WVO, but rather to know what you are getting. It seems that some people collect WVO with some harsh cleaning chemicals improperly disposed in the oil. The result is injector failures in trucks running contaminated WVO or even home-brewed bio. The moral of the story is to talk to the people who are supplying your oil, and coach them on proper disposal methods to ensure your oil isn't tainted.
Just thought I would pass this info along to WVO enthusiasts as a "heads up", just in case someone isn't aware of this potential issue.
__________________
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's
478hp/851tq on Haller's dyno - 7/28/12
Your connection to the Colorado diesel community.
Valid concern. Most places do not use it though. Once ya know what it smells like, you'll know to avoid it if your dewatering/filtering/conversion (bio-d) process does not remove it.
Mist washing is effective at removing it because the acid is soluble in water - but not oil. We have made 100's of gallons of B100 using boil out 'contaminated' VO. The BioPro 190 utilizes a triple mist wash, effectively removing any that may remain at that stage...
It can be tested for by placing WVO or B100 in a container, adding water and agitating. After the water separates, test it for Ph using litmus paper.
I actually ended up burning some of this in my F350 (2 tank VO conversion) shortly before changing injectors. (we normally set it aside for bio-d) The Swamps crew later showed me where this affected my injectors - although no 'pitting' was present, some parts were 'polished' indicating early stages of damage!! They also indicated that of the MANY VO injectors they've evaluated - boil out had caused the only real damage they saw.
__________________ 2000 Excursion, Limited, 4x4, Frybrid/V3 VO system, BTS trans, Gearhead tunes, Mahle pistons, 910 springs, chromo pushrods, headstuds, AC codes, T4/S366, carpet delete and other stuff. Also, 2001 F350 CC flatbed - currently w/no engine...
Quote:
Originally Posted by SpringerPop
There are none so blind as they who WILL not see, nor so deaf as they that WILL not hear. Pop-Psalm 4:44
I would say those failures were more due to improper prep of the fuel by the user not the fault of the oil itself. Those problems could be taken care of it the oil was filtered, washed (if needed) and dried.
__________________ Tim
1997 F-350 CC 4x4 PSD Auto 302K
AD's, IC, Rear Disc, OBA, Tuned by Tony Built by me! Transmission by Racer X!
