Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1961 - 1966 F-100 & Larger F-Series Trucks > 1961 - 1963 F100 Unibody
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
  #1 (permalink)
Old 02-09-2009, 08:15 PM
FoMoCoPower FoMoCoPower is offline
Garage is empty, add now
FoMoCoPower is starting off with a positive reputation.
Bought a `61 F100....BUT
Hello,I don`t normally post on here because I`m rarely stumped like I am right now.
I picked up a 1961 F100 unibody today. I assumed that all 2wd F100`s had 9" rears...but this one does not. When I was loading it on the trailer I was very suprized to a Spicer/Dana type rear axle under it. It has the correct 5 on 5.5" bolt pattern,and it looks to be the right width.
Would this be some sort of factory option,or was a 53-56 style rear swapped into my truck at some point in it`s life??
  #2 (permalink)
Old 02-09-2009, 08:25 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by FoMoCoPower View Post
Hello,I don't normally post on here because I`m rarely stumped like I am right now.
I picked up a 1961 F100 unibody today. I assumed that all 2wd F100`s had 9" rears...but this one does not. When I was loading it on the trailer I was very suprised to a Spicer/Dana type rear axle under it. It has the correct 5 on 5.5" bolt pattern,and it looks to be the right width.
Would this be some sort of factory option, Right-o! or was a 53-56 style rear swapped into my truck at some point in it`s life??
Welcome to FTE
Your truck has a LIMITED SLIP rear end if it's a Spicer-Dana 44.
When 1959/67 F100's were ordered with Limited Slip, the Spicer-Dana 44 was installed.
And...Ford also offered as an option, the Spicer-Dana 60 for 1961/67 F100's...with or without Limited Slip.
This 60 uses the same 5 lug, 5.50" bolt pattern wheels.
Look on your trucks Warranty Plate for the AXLE code, post what it is.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #3 (permalink)
Old 02-09-2009, 08:41 PM
Axle code is A1
  #4 (permalink)
Old 02-09-2009, 10:51 PM
BTW...also stumped on what these two codes mean...DATE: 222 and DSO: blank
What I do know is that it is an original paint Holly Green `61 Unibody shortbed 2wd,with a 223,light-duty 3spd,and it was the 644th unit built in March of 1961,so I am guessing within the first few days. My B-Day is March 4th,would be pretty sweet if this truck was the same...lol.
  #5 (permalink)
Old 02-10-2009, 03:59 AM
Ford Parts Guru
2013 Ford Escape
Axle code is A1
A1 = Spicer-Dana 44 / 3.73-1 / Limited Slip / 3300 lb. Rear Axle Capacity
The last line on the Warranty Plate should have the GVWR / HP / RPM / DSO code.
There is no date shown on the facsimile of the Warranty Plate in the parts catalog for 1961/62 F100/750's.
Suggest you post a pic of the plate. Ford didn't always stamp the codes in the correct location.
__________________
  #6 (permalink)
Old 02-10-2009, 07:16 AM
I will check again,but GVWR/HP/RPM are there for sure but no DSO.
  #7 (permalink)
Old 02-10-2009, 07:29 AM
Faber's Avatar
Faber Faber is offline
Faber is starting off with a positive reputation.
Mine doesn't either.
  #8 (permalink)
Old 02-10-2009, 07:32 AM
Faber's Avatar
Quote:
NEVERMIND......
your right like usual
4th number set, "53" nowhere near the 'DSO' title.....real far to the left.
  #9 (permalink)
Old 02-10-2009, 12:09 PM
Checked again,everything is there but the DSO,will take a pic to prove it.
  #10 (permalink)
Old 02-13-2009, 10:27 PM
So....no other opinions on the missing DSO or the Date:222???
I checked the tag a dozen times,the bottom row of codes has something for GVW,HP,and RPM,but the DSO is completely blank.
  #11 (permalink)
Old 02-14-2009, 10:04 AM
IsoGrifo's Avatar
IsoGrifo IsoGrifo is offline
IsoGrifo is starting off with a positive reputation.
date 222
perhaps it isn't march and it's February 22nd? as in 2/22
idk just throwing something out there.
  #12 (permalink)
Old 02-14-2009, 05:59 PM
garbz2's Avatar
garbz2 garbz2 is offline
1963 Ford F-100
garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.
A picture speaks a thousand words.
Garbz
__________________
98 528I BMW
64 F100 "Christine II" 390 NP435 6" lifted 2 wheel drive
63 F100 Uni Custom under construction 4" off the pavement and built to drive.
69 M250 Crew Hiboy 472 C6 Ranger, getting a full rebuild.
  #13 (permalink)
Old 02-15-2009, 11:37 PM
Obviously nobody believes anyone without a picture on here. Guess telling the truth means little nowadays.
  #14 (permalink)
Old 02-16-2009, 02:02 AM
Faber's Avatar
now, now....just take a pic, click on your name, create a gallery or whatever and upload it....
or, don't....doesn't matter to me....
  #15 (permalink)
Old 02-16-2009, 03:10 AM
Ford Parts Guru
2013 Ford Escape
Quote:
Originally Posted by Faber View Post
NEVERMIND......your right like usual
53 = Kansas City Ford District Sales Zone Office, where the original selling dealer ordered the truck from.
FoMoCoPower: It's has nothing to do with what some of us believe..or not.
Do you see what FTE member Faber typed above?
Ford mis-stamped code(s) on the Warranty Plates, put them in the wrong place, or may have left the code(s) off in error.
There's an old saying: "A picture says a 1000 words."
If you lived in Burbank CALIFORNIA, I could swing on by, and look at your Warranty Plate.
Can't do that since you live in Burbank....Illinois.
__________________
Tags
1959, 1961, 61, bolt, dso, f100, ford, limited, missing, pattern, slip, truck, trucks, unibody, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
