Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 02-09-2009, 07:20 PM
Pilgrim Pilgrim is offline
Garage is empty, add now
Pilgrim is starting off with a positive reputation.
Trailer wiring??
Have an '08 with the factory class IV hitch. Brochure says it has 4 & 7 pin connectors and brake hook-ups. I can only see a flat 4pin and the brake wire. Where is the 7pin?? Do some not have it? Can I add it easily? Thanks.
Pilgrim
  #2 (permalink)
Old 02-09-2009, 07:50 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Look where the jack is.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #3 (permalink)
Old 02-09-2009, 11:33 PM
Nothing there. Mine is a US model and the brochure I have is for a Canadian model. Seems the trailer towing package is only standard on the Canadian models. Owners manual says it's optional on this one. Only the 4 pin connector is standard. I'd like to at least have the 7 pin connector so it hooks to the trailers I have with 7 pin.
Pilgrim
  #4 (permalink)
Old 02-10-2009, 07:51 AM
clearnetedm clearnetedm is offline
clearnetedm is starting off with a positive reputation.
Yes I think your right. The other way to tell is if you have the extra tranny cooler that comes with the tow packadge.
  #5 (permalink)
Old 02-12-2009, 06:30 AM
chuck s chuck s is offline
chuck s is starting off with a positive reputation.
You have the Class III system, not the Class IV or HD Towing Option.
There should still be an electric brake controller under the dash and the blue wire should be back by the hitch "blunt cut, dipped, and taped." Any RV dealer will have the required round 7-pole adapter kit that will plug into the 4-pole boat trailer socket and have pigtails for the other connections.
HD Tow has all poles in the connector active, fused, and relay protected. I'll have to search to see if I have the wiring diagram.
Click the image to open in full size.
According to the Ford Towing Guide HD Tow boosts maximum towing capacity from an Explorer-like 6000 pounds to 9000 pounds. You must install the HD transmission radiator to get this boost in capacity. Also includes the wiring harness and a larger engine coolant radiator. At least one forum member had the transmission and engine radiators fitted at his Ford Dealer, they're standard parts. I recall he has a "Chevy" style forum name. Use the search function.
-- Chuck
  #6 (permalink)
Old 02-12-2009, 07:25 AM
Thanks Chuck (and others). I actually just made and installed the component you described last night from parts I had here on the shelf. I didn't connect the two 12 volt wires, though, so I actually have what acts like a 5 pin. I'm curious about the blue wire, though.? I didn't connect the "blunt cut, dipped, taped" wire yet. Are you telling me that if I simply connect it, my brakes will work? Don't I need to buy a controller box and install it in the cab? Or, are you saying (There should still be an electric brake controller under the dash) there already is one hidden under the dash somewhere??
The hitch itself is marked "Class IV 6000lbs". I don't plan to install the larger rad and likely not the cooler, either. I have a heavy truck for towing, but just want the option to use a light trailer if the need ever arises. I have all my trailers converted to 7 pole plugs just for convenience sake, so I wanted to put 7 on the Expedition as well.
Thanks again for your input.
Pilgrim
  #7 (permalink)
Old 02-12-2009, 07:46 AM
heymrdj's Avatar
heymrdj heymrdj is offline
heymrdj is gaining momentum as a positive member of FTE.
heymrdjlive
You have to supply the brake controller. Tekonsha I recommend you spend the extra $$$ on the proportional model instead of the inertia based. The P3's seem to be the most common. There's a connector under your dash. You order a brake controller, and that companies harness (the harness will plug in to your connector under the dash, and into their product). http://www.tekonsha.com/files/Vehicl...s%20042308.pdf From that chart you want part number 3035P. That's your wiring harness.
The blue wire must be plugged into your 7pin for this to work by the way :P.
__________________
2004 Expedition
Eddie Baur 4x2
5.4L 2v Triton V8
NEW: 2 3/4" pipe with Flowmaster Super 50 Delta Flow Muffler and 3.5"x18" echo tip WOOT
Upcoming:
Dual 16" Troyer performance fans
WAAG grill guard
Scanguage II
all corners air suspension
  #8 (permalink)
Old 02-13-2009, 05:58 AM
Yep you need to connect the blue wire. It connects under the dash board to the brake controller interface. If you get the Teknosha Prodigy or P3 with the $10 extra cost cable it just plugs in.
I've run both Prodigy and P3. The P3 fits my dash better. Here's where she plug in. (The blue device is a data capture thru the OBD2 port.)
-- Chuck
  #9 (permalink)
Old 02-13-2009, 06:01 AM
Add on:
If you think your towing package is marginal from a cooling standpoint fit a gage to monitor the temperatures.
This just plugs into the ODB2 Port.
-- Chuck
  #10 (permalink)
Old 02-19-2009, 10:49 PM
chevy24d chevy24d is offline
chevy24d is starting off with a positive reputation.
Hey Chuck,
I see pilgrim is all set, but if anyone needs more info on wiring all the wires for the 7 pin, let me know.
By the way, how much does that gauge go for? Where is the obd port located on our trucks? What is required to get the data - is it a simple plug-in?
Thanks,
Mark ("Chevy to Ford" ---- chevy24d)
__________________
2007 Expedition XLT - Black
  #11 (permalink)
Old 02-20-2009, 11:21 AM
emt932359 emt932359 is offline
emt932359 is starting off with a positive reputation.
I highly recommend the P3 controllel, works very well. You can convert the 4 pin to the 7 pin with a simple adapter kit. I did it on my 07 and works just fine. Be sure you have a good ground and very tight and moisture free connection for the trailer brake (blue wire), otherwise it will cause the trailer brakes to short occasionly. (learned the hard way)
  #12 (permalink)
Old 02-21-2009, 03:20 PM
The Ford version of the Interceptor runs $239.
The OBD2 port is directly under the steering column and shows the first photo of my 13 Feb message. There's a transparent blue data capture module connected to it.
-- Chuck
  #13 (permalink)
Old 02-22-2009, 08:22 PM
Thanks
Mark
__________________
Tags
02, 2007, 2008, 7pole, code, connection, diagram, expedition, f250, factory, ford, hitch, rv, trailer, truck, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
