cv axles binding up/whats a good programmer - Ford Truck Enthusiasts Forums
Old 02-09-2009, 05:13 PM
everythingperformanc's Avatar
everythingperformanc everythingperformanc is offline
everythingperformanc is starting off with a positive reputation.
when either of my front wheels drop during articulation they seem to bind up. the shop says nothing is wrong, but i beg to differ, b cuz when i jack the truck up enough to get a front wheel of the ground i can only turn it about 3 inches before it locks up. what is going on!
Old 02-10-2009, 08:44 AM
KingRanchMan02's Avatar
KingRanchMan02 KingRanchMan02 is offline
KingRanchMan02 is gaining momentum as a positive member of FTE.KingRanchMan02 is gaining momentum as a positive member of FTE.
Welcome to FTE everythingperformanc! Is your suspension stock or is the truck lifted? Are the torsion bars cranked up?
If the suspension is stock like it rolled off the production line and you have this problem then I would agree that something is wrong. But if things have been altered then you may have to add more modifications to get the suspension geometry back to normal.
I like the programmer that I have listed in my signature. Good luck!
Old 02-10-2009, 11:09 AM
dadlovesfords's Avatar
dadlovesfords dadlovesfords is offline
dadlovesfords is starting off with a positive reputation.
You don't have a locker up front do you?
Old 02-10-2009, 02:26 PM
Its all stock, no locker, but does have the 2 inch leveling kit. its the torsion bar one. it also has new cv axles, but the prob was there b4. it doesnt bind going up just down? even going down the road if u come of a hill an the tires drop it does it im stumped guys????????
Old 02-10-2009, 02:30 PM
I have seen guys having trouble with aftermarket CV axles. Maybe that is your problem.
Old 02-10-2009, 02:32 PM
BLK94F150 BLK94F150 is offline
BLK94F150 has a great reputation on FTE.BLK94F150 has a great reputation on FTE.BLK94F150 has a great reputation on FTE.BLK94F150 has a great reputation on FTE.
How about an limited slip?
Is the front driveshaft actually disengaging when you take it out of 4wd? Are you in 2wd or 4wd when you're testing this?
When you're driving it does it slam to a halt?
Mike
Old 02-10-2009, 03:31 PM
Bobby82490's Avatar
Bobby82490 Bobby82490 is offline
Bobby82490 is gaining momentum as a positive member of FTE.
Quote:
Most likely the leveling kit puts the cv axles at extreme angles when drooped, try backing down the torsion bars some to see if that helps.
Old 02-10-2009, 05:34 PM
well i tried backing off the t-bars an i still have the same problem. i guess i will have to live with the noise an see what breaks and post it up for the next guy.. thanks again for all the help. i picked up the edge evolution programmer an WOW what a difference. im sure ill break whatever in glamis this wknd
Old 02-17-2009, 03:43 PM
Well guys it broke! but not the cv axles. it was the housing coming out of the pumpkin on the drivers side. it snapped in half anybody ever break that before?
Old 02-17-2009, 05:30 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD BURNSTOUGHFORD is offline
BURNSTOUGHFORD has a good reputation on FTE.BURNSTOUGHFORD has a good reputation on FTE.
I want picks and video
Old 02-17-2009, 06:05 PM
i dont have any videos but here are some pics. does any one make an after market housing or support so this does not happen again? i cant seem to post pics so i put them in my pics area. hope you can see them. let me know
Old 02-17-2009, 06:11 PM
photobucket.com
Old 02-17-2009, 08:47 PM
Bobby82490's Avatar
It most likely happened because the cv axles were at a extreme angle, what you will have to do is either lower it back to stock or find a way to lower your differential. Take a picture of the cv axles so we can see the angle they are at.
Also take off the front cover on the axle and take a picture of that too.
Old 02-17-2009, 09:53 PM
To see his pictures, click on his user name and then on view public profile. the picture album is to the lower right.
Old 02-18-2009, 01:32 PM
So i talked to dixon bros racing who im someday going to buy my long travel set up from, an they say that its caused from the new cv axles i bought from auto zone. they are built chraper an do not give the angle tbe oem ones would. what the heck is up with that, but it makes sense why it would bind an stress the housing. so DONT BUY THE NEW AXLES FROM AUTO ZONE!!!!!!! i guess i will b buying that part an driving it easy till i get the cash for the long travel. oh well. atleast we all know what the problem is now.
Sounds Like Rear End Binding When Backing Up to the Right KeysMako192 6.7L Power Stroke Diesel 54 01-27-2016 07:15 PM
Binding in steering wheel. Platinum08 1999 to 2016 Super Duty 15 06-10-2015 05:37 PM
2002 Explorer, new brakes binding Recoil Rob Explorer, Sport Trac, Mountaineer & Aviator 10 02-07-2015 12:45 PM
binding in turns? 86f250hd 1987 - 1996 F150 & Larger F-Series Trucks 5 11-25-2014 03:29 PM
66 F100 Manual steering binds rderr 1961 - 1966 F-100 & Larger F-Series Trucks 13 08-28-2013 06:35 AM
Tags
2004, 35l, 4x4, axle, axles, binding, cv, cvshaft, duratec, f150, ford, fx4, long, programmer, travel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
