Muffler Bracket Suggestions
I just bought a Walker 18577 SoundFX muffler and it doesn't have the bracket on it my stock 1999 muffler does. I could just rig something but would like to see what others did to support their exhaust by the muffler. I obviously want something durable and would work as well as the original.
I don't have a welder readily available.
What did you do?
What did you do?
You know, that's exactly what I was thinking of doing. The rod is U-shaped with two insulators so I was going to bend up two sections and clamp them to the tail pipe section. Then when I got a hold of a welder I was going to weld them to the pipe or most likely the clamp.
Steve, is 5/16s the same size as stock to fit into the holes of the insulators? Things are a bit crusty down there and I can't get an accurate measurement.
adipose
04-09-2008 02:44 PM
