E40D Shifts hard 94 F150
I have a 94 F-150 4X4 long box. It has the E40D tranny with a 5.8. Th the truck shifts hard from 1st to 2nd and then shifts a little better as the gears go higher. Tranny fluid and filter just cahnged about 4,000 miles ago. I just changed the MLPS and after hooking the battery back up it drove and shifted perfect for about 10 miles. Shut the truck off and drove it a few hours later and i am back where i started. Hard shifting. My next idea is to change the TPS. Any ideas would be appreciated.
Thanks,
Jamie
Thanks,
Jamie
I am no trans expert but it sounds like you do have a sensor fault. Is your speedometer reading OK?
The MLPS and TPS are good guesses but that is all they are. I think you should the error codes, they can sometimes be a lot of help. If you have an OBD1 code reader then you can use that otherwise go to fordfuelinjection.com for instructions on reading codes from the check engine light using a paperclip. To get the transmission codes I think you have to floor the gas pedal while reading the engine off codes. Give that a try before you buy any more parts.
The guy at the tranny shop I took my truck to said the store bought code scanners for these trucks are junk, before I even got to telling him the codes. Best (and cheapest) way to check codes is with a piece of wire in the plugs under the hood and watch the CEL or use a test light.
They found two wires in the transmission harness that were corroded off of a connector (shift solenoid code) and replaced the MLPS which I knew it needed. Tranny has worked like new ever since.
Scott
Scott
Check those codes as soon as possible. I had a similar circumstance with my truck and ignored it. Eventually I blew the tranny. Very expensive mistake. The tranny guy told me that it was probably the solenoid pack in the trans as there was a code for it in the computer. Apparently, that hard shifting in the lower gears was a sign of solenoid failure.
I don't know squat about trans but all i can say is i have the same trans in my 91 f-150 5.0 and it's been hard shifting for as long as i can remember, my dad(previous owner) said it's done it forever and never had a problem, except that it gives you whip lash when it shifts from 1st to 2nd sometimes 3rd if you downshift and get on it real hard.
Kyle
Kyle
hard shiften tranny
I have an early model 1997 F250 HD 460 with the E40D tranny 135,000 miles bought it new in 97 and the shift is still hard but under load or climbing steep grade it will smooth out. I have had no problems with it just replace the tranny filter & power flush it every other year.
jimbo beam
07-27-2023 09:25 AM
brolandscape
10-30-2015 02:30 PM
94f2507.3
19
12-07-2014 05:18 PM
Raise
11-01-2014 09:03 AM
whitetailhunter
10-10-2005 03:06 PM
