351M spark plug gap? - Ford Truck Enthusiasts Forums
Old 02-08-2009, 12:34 AM
OrangeJuice OrangeJuice is offline
OrangeJuice is gaining momentum as a positive member of FTE.
Question 351M spark plug gap?
Hello,
Can anyone please tell me what the spark plug gap for a 351M engine is?
Thank You
Old 02-08-2009, 08:47 AM
firstonraceday's Avatar
firstonraceday firstonraceday is offline
firstonraceday is gaining momentum as a positive member of FTE.
With the factory Duraspark ignition, .042 - .046
Old 02-08-2009, 11:10 AM
skunktruck's Avatar
skunktruck skunktruck is offline
skunktruck is starting off with a positive reputation.
hi sorry to buzz in. what do you think the gap should be when running an MSD system?
thanks
jim
Old 02-08-2009, 12:36 PM
This truck has the factory ignition spark set-up. So, sounds like .042 - .046 will work?
Old 02-08-2009, 01:34 PM
skunktruck's Avatar
Hey OrangeJuice,
My 78 400 is set at .44 i belive i read that in some manuel
Old 02-08-2009, 03:51 PM
Quote:
Yes, somewhere in that range. I generally gap mine at .044.
As far as aftermarket ignitions (Mallory, MSD, Crane, Jacobs, etc.), some recommend opening up the gap due to more electrical current being available with their system. You'd just need to play with the gap based on the recommendations of the respective manufacturers.
Old 02-08-2009, 10:34 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
I believe 42-46 is correct, there should be a sticker on the radiator support and/or valve
cover that should specify.
Old 02-14-2009, 07:47 PM
Red Ford Truck's Avatar
Red Ford Truck Red Ford Truck is offline
Red Ford Truck is gaining momentum as a positive member of FTE.
Talking I run a MSD Street Fire and TFI coil.........
Quote:
thanks
jim
I run 8.5 mm wires and premium cap and rotor and have my plugs gaped at .60 the truck runs great with smooth idle and great performance.
The TFI coil is the difference, I could have bought a Blaster oil filled coil but the TFI Ford coil does a better job and you can pick one up at the auto wreckers for cheap, also make sure you remove the resistor form the ignition wiring it has one, the one that goes to the coil.
Rick.
Old 02-14-2009, 07:51 PM
skunktruck's Avatar
so you think going from .44 to .50ish might lean it out a bit?
Old 02-14-2009, 10:57 PM
Yes I do believe.
Because it is multiple Spark Discharge(MSD) with the wider gap and longer spark jump time I believe the air fuel mixture will burn more completely or less raw fuel unburned.
You still require a good coil to give a great spark in order for this to work.
Rick.
Old 02-19-2009, 10:51 PM
blue350 blue350 is offline
blue350 is starting off with a positive reputation.
thanks
jim
Should be .10 more so aroun .50 to .54
Old 04-28-2012, 03:03 PM
misfit1981 misfit1981 is offline
misfit1981 is starting off with a positive reputation.
1978 F150 4x4 351m/400
I'm running a Mallory Dist, Accel Cap/rotor, and MSD 8.5 wires...
What should my gap be?
Also what is the 351m speck for spark plug torque?
Thanks!
Old 04-28-2012, 04:28 PM
mustang81's Avatar
mustang81 mustang81 is offline
mustang81 is starting off with a positive reputation.
7-15ft.lbs.for 14mm and 15-20ft.lbs. for 18mm plugs.
Old 04-29-2012, 11:51 AM
Quote:
Thank you! Time for a new torque wrench...
1964 292 Spark Plug Gap jvwhittaker Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 4 08-11-2010 12:24 AM
Spark plug gap?? March bracket on a 351M?? crakerjack51 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 1 02-23-2008 05:33 PM
Spark plug gap for Propane 302? SAUKA Electrical Systems/Wiring 2 01-14-2004 11:43 AM
Spark plug gap?? elstx 1967 - 1972 F-100 & Larger F-Series Trucks 16 09-18-2003 06:17 PM
Spark plug Gap traildawg Ford Inline Six, 200, 250, 4.9L / 300 3 06-25-2002 10:22 AM
Tags
1977, 1993, 1997, 351, 351m, engine, f0rd, f150, ford, gap, modified, plug, plugs, remove, spark, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
