Can’t get to the distributor hold down bolt to loosen it
Old 03-20-2019, 11:21 PM
GlennB's Avatar
GlennB
GlennB is offline
Unhappy Can’t get to the distributor hold down bolt to loosen it
I feel dumb asking this, but I simply can not get any tool down under the distributor to loosen the hold down bolt. I have a 78 F 150 351W with factory air and the compressor seems to block access to the hold down bolt and clamp. Also a big casting boss on the bottom of the distributor above the bolt. Really frustrating me. I just found the truck and trying to work through rough running issues step by step. Saw that Someone wired the cap wrong, #8 on the #1 terminal, proper firing order, just a whole pin off all the way around the cap.Now Putting on new ignition wires on the proper pins so as part of basic correction and tune up I need to crank the distributor back to point the rotor at # 1 close to TDC where I have the engine now. I can see it’s a half inch bolt head, but can just barely touch it with tools. Am I missing something here, seems like it should be simple. I could really use some help? Should I dismount the A/C compressor?? Driving me nuts.
Old 03-20-2019, 11:32 PM
GlennB's Avatar
GlennB
GlennB is offline
Unhappy
Here is a picture from the only side I can see it from, can’t get even a 1/4 socket on it or a wrench. Is this normal??
Old 03-20-2019, 11:43 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
Well you see,way back in my days when computers didn't set the timing for you lol.............You need whats simply called a distributor wrench.
Old 03-21-2019, 11:36 AM
ctubutis's Avatar
ctubutis
ctubutis is online now
These things work well:
Old 03-21-2019, 12:19 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
You need the short return distributor wrench. There is a craftsman wrench made for the Ford distributors. Its available used on ebay.
You want the upper one for Ford distributors, the rest cover GM, AMC, Chrysler
Old 03-21-2019, 10:44 PM
GlennB's Avatar
GlennB
GlennB is offline
Thanks you guys. I have a curved , sort of half moon shaped one for Chevrolet rear distributors and it’s 9/16 not half and won’t fit any way. I actually ordered one of each of these today from Amazon and EBay to see if one or both will work!! I can’t believe everyone on this forum has these to work on their distributors. Can’t believe it takes a special tool. Should be here soon and I can line up TDC with the number one on the rotor and cap .
Old 03-21-2019, 11:03 PM
ford390gashog
When you work on older equipment there is a lot of non common tools that are mandatory. Kind of like ignition pliers and spark plug boot pullers.
Old 03-21-2019, 11:10 PM
FORDF250HDXLT
Well,they used to be very common tools and you just had the ones you needed in your toolbox.Just as common as a pair of pliers back then.Some guys would carried theirs with them.Adjust (advance) their timing a bit for street racing and set it back for every day driving after a race.
Old 03-22-2019, 08:08 PM
GlennB's Avatar
GlennB
GlennB is offline
Thanks guys, the distributor wrench actually worked and got me from one jam into another now. Pretty sure it wasn’t made of American steel as it twisted but did pop the bolt loose. Couldn’t believe it. Now can plainly see that I can’t retard the distributor far enough to get the rotor anywhere near number one at TDC , so I’m gonna check the forum to see what that’s all about. A mis installed distributor probably .Actually well into the next contact, what should be #7 at full retard. I guess somebody way worse than me worked on it.
Thanks Again.
Old 04-03-2019, 07:27 PM
tbear853's Avatar
tbear853
tbear853 is offline
Received 1,268 Likes on 1,073 Posts
Well, I've used mine maybe only once in last 20 years. Not an often used tool these days, but when needed, it's needed.
Old 04-07-2019, 03:11 AM
madrockwyo's Avatar
madrockwyo
madrockwyo is offline
The distributor is just a tooth or two off between the distributor gear and the cam. instead of correcting distributor, the previous owner just moved wires one terminal over on the cap. the fix is simple, just pull up distributor and rotate the rotor slightly when droppiing the distributor back in place. it only takes a few degrees of rotation, then a slight wiggle as the distributor seats to get the gears to mesh.
its npt uncommon to have it be a tooth off when you initially time it, if the gears hit teet when installing the duistributor, a slight rotation either clockwise or counter clockwise will get gears to mesh, one way is correct, the other way a tooth off. And normally, its only evident which one is correct when you actually try to rotate distributor to time it.
Old 04-13-2019, 03:26 PM
baddad457's Avatar
baddad457
baddad457 is offline
It's not the tooth engagement stops it, it's the oil pump drive shaft out of line.
Old 04-19-2019, 08:43 AM
artscott61's Avatar
artscott61
artscott61 is offline
Make your own tools from garage sale tools. Just bend and go that is what we did years ago. Good Luck.
D.K
10-19-2015 04:16 PM
saxtonj
02-02-2012 09:10 PM
bcsbadboys
11-20-2006 01:57 PM
faroffthetrack
04-23-2004 11:21 PM
garageinc2001
1983 - 2012 Ranger & B-Series
07-25-2003 10:54 AM
Quick Reply: Can’t get to the distributor hold down bolt to loosen it
