P1506 obd code question - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 02-07-2009, 09:56 PM
uno uno is offline
uno is starting off with a positive reputation.
After getting p1506 overspeed code. Replaced iac and still have higher than spec idle ( 1100 + - ) and restarted the truck after disconnecting the battery and code is gone but high idle is still about 1100. Anyone have an idea what iam missing checked some of the top side vac hoses and they seem good.
Old 02-09-2009, 07:23 PM
Gevans17 Gevans17 is offline
Gevans17 is gaining momentum as a positive member of FTE.
1506
try cleaning your throttle body
Old 02-09-2009, 08:14 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
I'd say look a little more for a vacuum leak.
Old 02-12-2009, 09:25 PM
uno uno is offline
i THINK its a vacum leak, hard to hear the spot. replaced the IAC hoping that was it. base idle should be 780 in nuetral. idles at 1100 nuetral,750-800 in gear and lower with air - point me in the right direction pls. ever had the same type problem yourself ?
Old 02-12-2009, 11:34 PM
I've had this problem on other vehicles in the past and it was always a vacuum leak.
Old 02-13-2009, 07:06 AM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Drive it for a few weeks until the MIL comes back on and then re-scan it. The new fault code should give you better guidance.
Steve
Old 02-21-2009, 06:44 PM
uno uno is offline
hey alloro, getting back to you after new IAC and TPS code cleared..........now its back with an idle at 1100 rpm, please help if you know a good spot to check for vac leak.....or ?
Old 02-22-2009, 12:41 PM
Did you try disconnecting the battery for 10 minutes to clear out the previous idle parameters?
Old 02-22-2009, 07:57 PM
uno uno is offline
Thumbs up solved
after a new TPS and IAC.......my only problem was the PCV, base idle 600-650, for a whopping $3 ( finacing available with approved credit ) haha
Old 02-22-2009, 09:01 PM
Ahh so it was a vacuum leak after all.
High idle Gerryatrics 1997 - 2003 F150 19 03-30-2014 06:11 PM
1999 F150 5.4L error code P1506 pleshdog21 1997 - 2003 F150 1 09-10-2013 06:42 AM
code P1506 pfpost 1997 - 2003 F150 5 08-10-2011 01:19 PM
dtc 1506 after head gasket job morrowtruth 1997 - 2003 F150 0 04-11-2010 03:06 PM
workin on 96 f 150 trouble codes firefighter1416 1987 - 1996 F150 & Larger F-Series Trucks 4 02-13-2010 05:30 PM
Tags
02, 1506, 1997, 1999, 2001, bronco, code, dtc, escape, expedition, explorer, ford, lincoln, obd, p1506, trouble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
