Transmission wont shift into overdrive
I just got through putting my new (used 22k mile) transmission in, it shifts fine except it wont shift into overdrive. Also the tow haul light starts flashing when it shifts from first to second. It doesnt give me any codes but I can turn off the tow haul light with my scan tool.
I have an update, After you first crank the truck it will shift fine through first, and second then it has a bit of a clunk as it shifts into third at the same time the tow haul light comes on and begins to flash. also if you hammer the gas the tow light will come on and it shifts into third. It will not down shift either. also the 4WD low range does not function, I have unplugged the battery twice with the same results.
Ok Im an idiot, I read the manual and it explained how to put it in 4 low and it works fine. But I still have the same shift problem, once it gets to about 1900 rpm it wants to go into 3rd and not come out until you turn it off and on again. Even if you come to a stop it stays in 3rd. I swapped the sensor on top with the one from my old tranny, it looks like a speed sensor, I guess anyway same result. Im off to the stealership Monday for my raping because my new OBII sensor that is supposed to be CAN compatable will not read the code when the tow light is flashing, but it will turn it off?????
<TABLE style="WIDTH: 677pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=903 border=0 x:str><COLGROUP><COL style="WIDTH: 677pt; mso-width-source: userset; mso-width-alt: 33024" width=903><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD class=xl26 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 677pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=903 height=17>Torqushift Shift Relearning Strategy</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 677pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=903 height=17></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 677pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=903 height=17>TorqShift Harsh/Slipping Engagements, Upshifts, and/or Downshifts:</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl27 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 677pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=903 height=17></TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 677pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 25.5pt; BACKGROUND-COLOR: transparent" width=903 height=34 x:str="If these symptoms are experienced after the batteries have been disconnected, then it is due to the transmission adaptive strategy being cleared from the computer. This may occur when the vehicle is delivered new from the factory as well. ">If these symptoms are experienced after the batteries have been disconnected, then it is due to the transmission adaptive strategy being cleared from the computer. This may occur when the vehicle is delivered new from the factory as well. </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 677pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=903 height=17></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl28 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 677pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=903 height=17 x:str="1. Warm the engine and transmission to operating temperature with all accessories off. ">1. Warm the engine and transmission to operating temperature with all accessories off. </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl28 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 677pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=903 height=17>2. Idle engine for one minute with engine warm and all accessories off.</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl28 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 677pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=903 height=17>3. Idle engine for one minute with A/C on.</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl27 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 677pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=903 height=17></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 677pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=903 height=17>Then:</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl28 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 677pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=903 height=17 x:str="1. While driving, perform three series of upshifts at light, medium and heavy throttle. ">1. While driving, perform three series of upshifts at light, medium and heavy throttle. </TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD class=xl28 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 677pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 25.5pt; BACKGROUND-COLOR: transparent" width=903 height=34 x:str="2. While stopped, perform three sets of gear engagements (N-R, N-D, D-R, R-D) with the brake pedal firmly depressed and waiting three seconds between each engagement. ">2. While stopped, perform three sets of gear engagements (N-R, N-D, D-R, R-D) with the brake pedal firmly depressed and waiting three seconds between each engagement. </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 677pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=903 height=17></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl28 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 677pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=903 height=17>Perform these steps once in normal mode and once in tow/haul.</TD></TR></TBODY></TABLE>
Note - the Tech folder has been updated.
That's not going to help. The relearning the shift pressures will only help with shift smoothness, he's got something wrong.
The only way to fix this is to find someone that can read the code that was stored when the tow/haul light flashed. That will tell you what's wrong.
Mark,
Im taking it to the ford dealer tommorow to see if they can pull the code. I still have my old tranny, Just in case it is a solenoid, I was thining I could use a good one from my old trans. I have checked them with an OHM meter and all but one are showing 4.5 OHM except for one, its on the far left of the row with four solenoids, it is showing about 5.4 OHM. Do you have a way I can test with my multimeter? Can I put 12v to them and see if they actuate? with that destroy the solenoid
Update transmission fixed
Took it to the Ford dealer this morning, took about 30 min. Hooked it up to the scan tool and found code P0720 "OSS sensor not plugged in correctly" All is well with my new tranny now. I will be replacing the egr cooler Im going to block this one off, and a new oil cooler (oil in my coolant tank) The guys in the shop told me to just use freeze plugs and 3M sealant on both ends of the egr cooler, He said his has been done that way for 30K with no problems, Also they said the truck was missing on the #6 cyl. and it had a couple of egr codes that were set off, they said to check the Y pipe when I do the cooler. Im just tickled that it only cost me $64 for the tranny.
They said it was the fuel injector. I just bought a new one off of ebay $129 shipped it was the only one he had, I thought that was a great price for a new one, the rebuilt were 150+. not including a core.
jst3751
1999 to 2016 Super Duty
07-06-2016 11:56 AM
Im50fast
44
05-18-2016 07:26 PM
