Early 1999 F350 SD Front Wheel Bearings - Ford Truck Enthusiasts Forums
Old 02-07-2009, 03:04 PM
The1999Beast's Avatar
The1999Beast The1999Beast is offline
The1999Beast is starting off with a positive reputation.
Exclamation Early 1999 F350 SD Front Wheel Bearings
I have a 10/98 mfr date 1999 F350 SD and I've read about this wheel bearing conversion kit to later 99 so it will be cheaper to fix. Is this true? What do I replace after installing this kit? Just the bearings themselves? I did one and the replacement part was ridiculous expensive(list price was almost $1000!!!!) Luckily I just had to pay about $6-700 for it.
wheel studs beemr 1999 to 2016 Super Duty 0 04-19-2010 11:43 AM
Part Number?? Front Wheel Bearing hub? OUTPLAYN 1999 - 2003 7.3L Power Stroke Diesel 7 12-26-2007 11:18 AM
Front Wheel bearing/Hub Replacement rideac 1999 to 2016 Super Duty 3 11-12-2006 10:02 AM
1999 Hub/Bearings vs. 1999.5 Hub/Bearing mizzitch 1999 to 2016 Super Duty 13 12-14-2004 06:24 PM
Wheel Bearings Big money 1999 to 2016 Super Duty 28 11-26-2004 07:49 AM
Tags
1999, bearings, early, f350, ford, front, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
