i was looking at an 2005 F150 cc shortbox FX4 package.
it has the center console but no tilt wheel, i have never seen this is this something normal or a unit that has been wrecked.
It should have tilt. the lever is under the steering column. You pull in down, set the wheel where you want it then pull the lever back up. The lever is flush with the underside of the column.
my 2006 has the tilt....it might be just a package thing. The FX4 is a package that bridges the gap between XLT and Lariat. So some are Lariat optioned, and some have just about nothing
