7 pin HD trailer wiring diagram - truck side - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-06-2009, 06:23 PM
canadianfordguy canadianfordguy is offline
canadianfordguy is starting off with a positive reputation.
Does anyone happen to have the pinouts for the OEM ford plug that plugs in the 7 pin connector behind the bumper?
2000 Ford Excursion - I'm trying to replace the 7 pin plug with an aftermarket plug that requires me to cut/splice.
Pics will follow.
Old 02-06-2009, 06:24 PM
Old 02-06-2009, 06:26 PM
I'm trying to figure out the grey plug
Old 02-06-2009, 06:30 PM
orange
green
yellow
blue
white
brown/white stripe
black/green stripe
Old 02-06-2009, 06:35 PM
rbaker6336's Avatar
rbaker6336 rbaker6336 is offline
rbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to behold
Fords trailer brakes saltbranch Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 13 11-26-2013 05:36 PM
Ford factory 4 pin connector pins too short gjf250 Electrical Systems/Wiring 1 06-03-2012 08:36 PM
trailer wiring harness with 4 pin and 7 pin plug bossgobbler 1999 - 2003 7.3L Power Stroke Diesel 11 10-27-2011 09:18 PM
Installing a 7 pin plug campin' nut Electrical Systems/Wiring 4 12-23-2006 07:03 AM
7 pin trailer adapter plug/harness termyt00 Electrical Systems/Wiring 3 10-15-2004 07:01 PM
Tags
connector, diagram, duty, ford, heavy, oem, pin, pinout, side, stripes, super, system, trailer, truck, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
