Spark Plug Question
Spark Plug Question
I have a 2000 E150 with 4.2 engine that has 117k miles. The van has the original spark plugs in it.
I was told by a mechanic that I should run these plugs until I notice a miss. I suspect he didn't want to change them for me. They do appear to be hard to get to on this engine. I'm not too sure I could do it. The Ford dealership want $125 + parts to do the job. They will probably advise me to get new wires also. I can see this costing at least $175 total at the dealer.
Should I do as the first mechanic suggested and wait until it misses, or should I take it to the dealership? Other sugestions?
Thanks for the advice.
I have a 2002 E150 with a 5.4L engine. I just replaced the plugs. It was a pain because there isn't much room to work. I did need to unbolt a fuel rail mount in order to get a plug wrench on some of the plugs. I think the worst part was trying to get a wrench on some of the COP retaining bolts. Overall, it wasn't a hard job but it did take me about 4 hours. Make sure you use a torque wrench when you put the new plugs in the heads. If I were you, I wouldn't let those plugs go any longer. The longer you leave them in, the harder they are to get out.
Good price, I would have them do it. At 117K, they might not be that easy to remove without damage.
7 mm swivel from Sears.
> Waiting for a miss isn't a good idea.
I agree and think you need another mechanic as he gave you really bad and stupid advice.
whalerron how did you go about changin COPS on your van can you give details im hopin to change my friends sparks soon was it really difficult & any good advise it does look kinda crowded all in there i did change my dads 5.4 COPS & PLUGS F150 but never a Van just yet but am lookn up for the challenge. any good advise & details would be appreciated thanks!
I recently replaced the plugs, wires, cap, and rotor on my 95 E150 with the 351. I know this van is slightly different than yours, but I took out the alternator and all of the air hoses to get to the cap and plugs on the passenger side, and it took about an hour. I certainly wouldn't go to the dealer for a tune up.
Hope you do not use that so called "mechanic" for anything. You need to change the plug. Personally, if you do not work on your own vehicle all the time, it might be worth it to pay the dealer to do it. Especially if the plugs are stuck in there.
That being said, the 4.2 in the van is easier then the 5.4 in a truck, I would go for it.
HelenB
05-17-2016 04:38 PM
elecman0415
Modular V10 (6.8l)
12-16-2010 03:48 AM
