You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I had a set of aux reverse lights installed on my Expy, would it be bad if I added an additional set of lights on the same wire harnness?
The reason is because the first set is positioned so that it projects out to the corners of the truck, Im looking to installed a second set to illuminate staight out the back on the same switch.
__________________ 2007 Ford Expedition XLT 4X4
Husky Liners Molded Mud Guards ~ Ford OEM Side Window Deflectors ~ WeatherTech Floor Liners & Cargo Liner
Tinted front windows ~ Hunter Bull Bar ~ HIDX 4" HID lights ~ 4" Magnaflow SS rolled angle exhaust tip
I would recommend a dedicated 10 gauge wire that is relay activated.
Take power from the battery to a fuse holder.
Use a 30 amp fuse.
Run wire to relay terminal 30.
From relay terminal 87 run wire to rear of vehicle and mount a distribution block. 6-Position Dual-Row Barrier Strips - RadioShack.com
use jumper to feed power to each terminal 8-Position Jumper - RadioShack.com
Feed each light unit from terminal block
Run wire14 gauge from backup light circuit to single pole double throw (On-Off-On) switch side terminal.
Run 14 gauge from power source through a 5 amp fuse to other side terminal of switch.
Run 14 gauge wire from center terminal of switch to terminal 85 on relay.
Ground terminal 86 of relay.
You now have a dedicated circuit for the lighting to the rear of your vehicle.
For added corrosion protection coat the distribution block with "Liquid Tape" after you have made the connections.
__________________
2001 E-350SD V10 Triton 3.73LS, ROTW 01/02/10
2008 F-150 FX2 Sport 5.4L 3.73LS Scab 145" Wb; '05 & '07 Taurus SEL's
Bryan L. Unique Collision Center Towing & Wreck Recovery Specialist
“Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
Find the power leads to the outlets.
Install a relay into the leads.
Power the relay so that it activates when the ignition is on.
Now the power outlets will go dead when you turn off the truck.
Outlet power supply lead to terminal 30 on relay.
Terminal 87 to outlet.
Ignition on lead to terminal 85.
Terminal 86 to ground.
__________________
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
