97 F150 Total Instrument Failure - Page 2 - Ford Truck Enthusiasts Forums
Old 07-31-2009, 10:08 AM
salukee salukee is offline
salukee is starting off with a positive reputation.
cmorningstar01 - Thanks
"The instrument cluster is actually fairly simple to remove and replace(10-15 minutes)" -
That seems amazing. It took a whole lot longer just to remove the fuse block to allow GEM replacement. Does the whole dash have to be pulled. If I search this site will I find a thread that has the directions to do this.
"The light switch must be removed to get to a screw that is located behind it which is probably the hardest part of the remove/install" -
What light switch- headlights?
Do you have an idea what the instrument panel sells for?
Old 07-31-2009, 10:18 AM
cmorningstar01's Avatar
cmorningstar01 cmorningstar01 is offline
cmorningstar01 is starting off with a positive reputation.
I thought they were the same myself and found out the hard way that they were different, he hardest part is the headlight switch removal and it has to come out as there is a screw behind it that holds the bezel in place, You can actually gently spread the bezel away from the dash in that area and slip a screw driver in and depress the detent that holds the headlight switch in place .
The whole dash not have to be removed, Just the bezels surrounding the cluster
Yes the headlight switch is the switch I am referring to as there is a screw behind it that has to come out
I paid $60.00 for a 98 cluster only to find it was wrong then hunted around and found a 97 cluster for $35.00
VJ
Old 07-31-2009, 11:59 AM
I found this link to a thread about getting the instrument cluster out. http://www.ford-trucks.com/forums/15...ent-lamps.html Not the greatest amount of details, but it is a start. I will start searching for a cluster.
Old 07-31-2009, 12:13 PM
A link with Pictures!
Old 07-31-2009, 12:21 PM
The photos will def help, It is not a hard job and unlike the GEM you do not have to lay upside down and backwards to get to it, You can do it all sitting in the drivers seat, I forgot to mention that I would recommend disconnecting the battery cables and that it helps if you put the truck in 1st gear(if its an automatic) which helps lower the shifter out of the way and don't forget to set the parking/emergency brake, I would also recommend replacing the bulbs with new so you do not have to take it apart again to replace a dead bulb later down the line, Overall it is one of the easier projects I have had to do on my truck, Once you have done it once(or twice in my case)it can be done in less than 15 minutes when you have the correct tools handy.
Good luck and let us know how you make out
Val
Old 07-31-2009, 07:41 PM
TonyDee TonyDee is offline
TonyDee is starting off with a positive reputation.
Success--partially. Replaced the cluster, all the gauges work now, except the tach. I will live with that.
Old 08-07-2009, 01:41 PM
Tach working--needad a "tap "on the cluster to get going.
Old 12-13-2013, 04:48 PM
mchittester's Avatar
mchittester mchittester is offline
mchittester is starting off with a positive reputation.
No instrument readings and no overdrive. Looked at all the fuses, looked good. Took to Ford dealership, $106.00 later fuse f29. Change your fuses that are involved with instrument panel and save some money.
Old 03-30-2016, 10:00 PM
docb969 docb969 is offline
docb969 is starting off with a positive reputation.
I have had the same cluster problem. Some of the lights will work and the other times it won't light up anything. So I started tapping on the back side of the cluster and half the gages came to life, but the fuel pump would not run. So at this point you have 2 choices replace it or have it repaired. I had my repaired and it cost me about 75.00 with the shipping. So remember if you replace the cluster you will have to take it to a shop or (Ford dealer) that can flash the new or used cluster to work with your ECM and PCM. All 3 work together on 97 and up Ford truck F-150 thru F-650, and it does not matter whether is Gas or Diesel. If you have your cluster repaired most likely it will not need to be flashed.
Old 03-31-2016, 06:39 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
That is incorrect. Only the 99-up F150s got PATS, 97 & 98 did not. The Super Duty line (except Excursion which always had it) didn't get it until the '08 MY.
No power to fuses Smokdivr28 1997 - 2003 F150 4 01-05-2016 06:54 PM
'00 f250 7.3 No Cruise+ABS Light On BHUNT300 1999 to 2016 Super Duty 2 11-29-2015 07:28 PM
VSS? 11b 1987 - 1996 F150 & Larger F-Series Trucks 15 06-30-2015 11:17 PM
pcm power problem!! bamaaa 1997 - 2003 F150 8 01-26-2015 08:15 PM
98 F150 Instrument Cluster Dead callman 1997 - 2003 F150 3 06-02-2008 05:01 PM
Tags
2004, 97, 99, cluster, electrical, f150, failed, failure, ford, gauges, instrument, power, radio, replace, windows
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
