paper work
Received 4,131 Likes
on
They make you jump thru hoops and want to know what brand ( Soft Touch ) and style ( single ply or double ) of TP paper you use . Had the same problem with the 1ST-RIDE .It was registered from Nov. 11 '51 till Aug '68 in Wis.Fla DMV said I had to get a copy of that from the Wis. DMV.So called Wis. DMV with the VIN. and they said that vehicle was never registered in Wis. After all the ph.calls adn argueing with DMV people my head hurt and I resorted to Coor's Silver Bullet !!!
The worst thing you can do to a person with Bohemian blood is to discourage them . It will only make one try harder .This will be accomplished one way or another .The other truck has a F6 ID plate and title . The officer only wanted to see the matching numbers . He was not intelligent enough to know what the numbers meant . As the saying goes there is more than one way to skin a cat .
Received 1,351 Likes
on
