dual exhaust on 93 bronco - Ford Truck Enthusiasts Forums
Old 04-09-2001, 11:56 PM
93bigbronco 93bigbronco is offline
93bigbronco is starting off with a positive reputation.
I want to get a dual exhaust. I saw one on a 87-91 bronco. Is there any place that sells a kit for this? Or do I need to make a custom setup? If I need to do a custom one, does anyone know exactly where to route the exhaust.
Old 04-10-2001, 02:25 AM
karljay karljay is offline
karljay is starting off with a positive reputation.
Some places offer kits, I've seen them in Jegs but I don't know about your specific app. I just wanted to say, that you should consider manderal bent tube for the exhaust. If you go to most muffler shops, they custom bend pipes for you right there BUT they are NOT manderal bent. A manderal bent pipe does not change in size, if you look at most stock pipes, they get smaller on the inside of the bend and this reduces flow.
Most truck can get away with straight pipes back pretty far, then you could buy some manderal bent pipe from Napa or Jegs and have the rest welded to get around the rear axle or to exit on the sides. Manderal bent pipe are not expensive, I've seen them in Jegs for < $20
Old 04-10-2001, 08:08 AM
oldblue18's Avatar
oldblue18 oldblue18 is offline
oldblue18 is starting off with a positive reputation.
On a Bronco it is better to route the exhaust to come out behind the back tires, the same location at the stock exhaust. If you have the pipes come straight out the back and drive with the rear window open, the exhaust will be sucked into the window. Or at least that's what the exhaust shop told me when they put duals on mine. Hope this helps.
Jon
Old 04-12-2001, 12:33 PM
79fordslug 79fordslug is offline
79fordslug is starting off with a positive reputation.
Need New Exhaust NJK570 1978 - 1996 Big Bronco 13 09-18-2012 12:11 PM
true dual exhaust kits? BACKWOODS99 1999 to 2016 Super Duty 5 06-23-2011 04:52 PM
Custom Bronco Exhaust and headers Insanebronchitis 1978 - 1996 Big Bronco 9 02-05-2011 01:40 AM
Dual exhaust for 6 cylinder canadian F50 1987 - 1996 F150 & Larger F-Series Trucks 16 07-15-2007 11:11 PM
Best Exhaust for 93 Full Size Bronco... TheHulk Exhaust Systems 2 12-30-2002 02:32 AM
Tags
1995, 351, 87, 93, bronco, dual, duals, duel, exaust, exhaust, exhust, ford, ii, jegs, kit, routing, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
