Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 02-04-2009, 05:13 PM
Steve_250's Avatar
Steve_250 Steve_250 is offline
Are we there yet?
Steve_250 is gaining momentum as a positive member of FTE.
Wire color for headlamp switch/Fogs
Looking for the wire colors to the fog lamps, want to put on seperate switch. My headlight knob broke off and had to super glue it back on.
__________________
2003 F250 PSD 7.3 LB 4X4, all the popular mods and others. Roadside Help Network Member
  #2 (permalink)
Old 02-04-2009, 05:58 PM
Monsta's Avatar
Monsta Monsta is offline
Sit. Stay.
2005 Ford Excursion
Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of
From the switch? It's a foglight capable switch?
I think it's white. IIRC, I tapped that one to switch a relay for the factory foglights I installed. I'll go check...
__________________
Ken
Cats; nasty creatures...
  #3 (permalink)
Old 02-04-2009, 10:53 PM
Banditmax Banditmax is offline
Banditmax is starting off with a positive reputation.
It looks like a yellow wire that goes from the light switch to the central junction box where the fog lamp relay is located. It should work like before in that you have to have your low beams on. If you wanted them to come on independent of the headlights you would need to bypass the fog lamp relay and put in a separate relay for the fog lamps. I believe that if there is a brown wire that loops back into the light switch you can splice into there and your fog lamp indicator will still work.
I hope this helps
Mikey
  #4 (permalink)
Old 02-05-2009, 12:18 AM
Steve_250's Avatar
Are we there yet?
I also think that if I go on a separate circuit to the fogs, they will have more juice. I like the idea of the fog indicator working on the switch Mikey....
Yes Ken, it is capable, I pull it out. But that's the problem, I pull it out and off comes the dadburn knob. I planned to put better lights up there anyway.
__________________
  #5 (permalink)
Old 02-05-2009, 05:54 PM
Steve_250's Avatar
Are we there yet?
Ken, did ya find out?
__________________
  #6 (permalink)
Old 02-07-2009, 03:16 PM
Monsta's Avatar
Sit. Stay.
2005 Ford Excursion
It's yellow. Banditmax was right.
I added OEM fogs to my truck. I got an OEm switch of eBay that has foglight controls.
I spliced the yellow wire to switch a relay that powers the fogs directly from the battery.
I changed the bulbs to 9006 bulbs by Dremeling out some material in the light housing. The bulbs are wicked bright and nearly negate the need for my regular headlights.
__________________
Ken
  #7 (permalink)
Old 02-07-2009, 06:12 PM
Steve_250's Avatar
Are we there yet?
Thanks Ken, I'll get to this on Wednesday...
__________________
  #8 (permalink)
Old 07-03-2009, 09:28 PM
Steve_250's Avatar
Are we there yet?
Just an update, a glob of super glue is still holding!
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
