I would physically check the engine for bare wires shorting or a vacuum hose leaking.
then I would use a fuel injector, dump it into the gas tank and let run to resolve the problem. If not, I would check the intake gasket by spraying carburator cleaner around the intake manifold. If the engine miss is gone, the its the intake gasket must be replaced.
If this doesnt resolve the problem, remove all spark plugs from the engine and preform
a compression test or use a cylinder leakdown tester.
I justed resolved a misfire on #1 cylinder PO301 code by replacing the plugs, then plug wires and last the coil pack, which resolved the problem.
Good luck
ldrotos
