2004 Ranger misfire - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
2004 Ranger misfire
Old 02-04-2009, 10:11 AM
bearring1 bearring1 is offline
bearring1 is starting off with a positive reputation.
2004 Ranger misfire
2004 ford ranger edge 3.0 misfires. It does it consistantly. The check engine light stays on all the time, but flashes when idliing. I have put it on a code reader and it said misfire on clylinders 1 and 2 I believe. I have changed the coil pack and CPS also. It has been doing this for some time now. It doesnt have any problems stalling out or starting up just misfires bad while running. Oh and you can also smell fuel while your idliing pretty strong. Any advice would be greatly appreciated!! And I have also replaced the plugs and wires.
Old 02-04-2009, 05:20 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
Do a compression test. See: Ford 3.0L Misfire TSB # 05-26-3
Old 05-01-2009, 11:10 AM
tlk401 tlk401 is offline
tlk401 is starting off with a positive reputation.
My B4000 4.0L was acting similarly. Intermittent miss but occurring most of the time with the check engine light alternating from flashing to solid. No code was showing either. Turned out to be a bad plug wire that was arcing on the engine causing the misfire. Trying running it at night and looking for a spark or listen for a crackle from the spark. May not be the problem but this happened to me with similar symptons. By the way the plug wires were only a couple months old so I never suspected them at first.
Old 02-10-2012, 10:21 AM
GCasey13 GCasey13 is offline
GCasey13 is starting off with a positive reputation.
Random Misfire
Having same issues. replaced plugs/wires. harsh idle with flashing chek eng light. What was your resolution?
Old 12-12-2012, 08:33 PM
Kelsey Denby Kelsey Denby is offline
Kelsey Denby is starting off with a positive reputation.
Question Multiple misfires
I am having similar issues. My 04 Ranger XLT had a couple of misfires, I took it in, and had the spark plugs and wires replaced. It did fine for awhile (maybe 5,000 mi), then the check engine light came on. It coded for three misfires: a misfire at cyl 5, a random misfire, and misfire after first 1000 rev. I've been told that replacing the cyl heads is the fix, but also that this particular engine has an issue with valves not sealing properly. And that this could be checked with a leak down test. What kind of repairs can I most likely expect and cost? Or should I just get rid of it?
Old 10-08-2015, 04:59 AM
MyFirstWasaFord MyFirstWasaFord is offline
MyFirstWasaFord is starting off with a positive reputation.
Been having the same issue and i cant figure out whats wrong. Cylinder 1 misfire but just replace spark plugs and the wires are all intact no singing or sparks and the coild pack seems intact and working probably. Guess im gonna go ahead and buy replacements anyways and see if that helps if not im moving on to the starter mext and after that if its not fixed the alternator although i cant see the alternator causing problems cause they would make much sense i think.
Old 10-08-2015, 08:52 AM
pawpaw pawpaw is offline
pawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to behold
Quote:
Welcome to FTE.
This is a 6 year old thread, so I'd suggest you go to the top left of this forums index page, click on the "New Thread" button, so you get answers just for your problem/s.
In the new thread scan the computer for set & pending trouble codes & post All code Number clues.
Don't begin a repair by throwing parts at a problem & hoping for joy. Take the time to properly trouble shoot the problem, Then replace the faulty part. The forum has experienced members that with good trouble shooting clues can likely guide you in your search for the root cause of your vehicles woes.
NEED HELP PLEASE: 2004 F150 XLT 5.4l (3v) misfire kulla 2004 - 2008 F150 4 12-14-2014 10:56 AM
2000 Ford Ranger 2.5 inconsistant miisfire Donaldhill Ranger & B-Series 1 11-14-2014 01:41 PM
2004 F250 V8 Gas misfire Santa 1 Modular V8 (4.6L, 5.4L) 12 01-10-2014 12:55 PM
2004 Ranger 3.0 misfire bearring1 3.0L V6 3 02-18-2010 11:22 PM
It runs awful when it rains 88 Bronco Ranger & B-Series 21 12-22-2009 12:46 PM
Tags
05263, 1999, 2004, 3, 30, accessories, code, edge, ford, ignition, misfire, no, problems, ranger, tsb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
