Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 02-03-2009, 11:57 PM
dutchlincoln79 dutchlincoln79 is offline
dutchlincoln79 is starting off with a positive reputation.
460EFI firing order, and tri-Y exhaust Q.
Hello,
I want to fabricate my own tri-Y header/exhaust, and i wonder how the firing order should be divided into the Y's..
Also need the exact firing order uf the fuelie 460EFI, in order to create the exhaust.
Can anybody enlighten me?
Thanks.
  #2 (permalink)
Old 02-04-2009, 05:58 AM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a good reputation on FTE. EPNCSU2006 has a good reputation on FTE. EPNCSU2006 has a good reputation on FTE.
The firing order should be 1-5-4-2-6-3-7-8. I've never worked out pairings for a V8, but on the I4 racecar I worked on at school, we paired every other cylinder in the firing order. Just as an example, the firing order was 1-2-4-3 and the pairings were 1-4 and 2-3. All those cylinders were separated by 180° of crankshaft rotation; each firing is separated by 90° on these V8s. Can you find any pictures of a Doug Thorley header? I know they have tri-y headers.
__________________
Eric
'87 F150 302 manual 4sp overdrive 4x2
  #3 (permalink)
Old 02-08-2009, 08:13 PM
Steve_L Steve_L is offline
Steve_L is starting off with a positive reputation.
Look at this...
http://www.stans-headers.com/Photos/...0&%20247YI.jpg
You should be able to figure it out with that pic...
  #4 (permalink)
Old 02-09-2009, 01:24 PM
Ex-CUSE-ME !!!
Those are nice!!
What brand are they?
Are these for the 460 EFI???
Wow!
  #5 (permalink)
Old 02-09-2009, 06:54 PM
Yes they are for an injected 460, and they're made by Stan...
[http://www.stans-headers.com/ford_headers.htm]
Yes they're expensive, but you get what you pay for...
Had to edit this URL because the forum software wouldn't parse it correctly...
  #6 (permalink)
Old 02-24-2009, 06:08 PM
dkf's Avatar
dkf dkf is offline
dkf has a good reputation on FTE. dkf has a good reputation on FTE. dkf has a good reputation on FTE.
Doug Thorley makes Tri-Ys for the the 460. I have a set of tri-y Thorleys on my 6.8l and the low and mid range power is superb.
Thorley Tri-Y Headers: DTE-214Y-FI5-C - summitracing.com
  #7 (permalink)
Old 10-25-2009, 04:19 AM
Can you shoot some pictures of it installed?
especially drivers side?
The (truck) engine is going in my lincoln, and on the pics i have to decide if they'll fit, so if i can see them installed, it'll be a great help!
thanks.
The Thorley and Stan's connect the same cilinder order, so there won't be a difference in that.
Ideally i "think" there are better connections...
i would say that 1+2, 4+3, 5+7, and 6+8 would be the best cilinders to connect...
On the other hand... Company's like these probably know better than i do...
Tags
460 , 68 , connecting , efi , engine , fireing , firing , ford , headers , order , picture , tri , v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
