Help to remove outside door handles on 40 pickup - Ford Truck Enthusiasts Forums
Old 02-03-2009, 08:59 PM
Gord4048 Gord4048 is offline
Gord4048 is starting off with a positive reputation.
Post Help to remove outside door handles on 40 pickup
Hello- I am new to truck restorations but have done several frame off car restorations.Currently a friend and I are restoring 2 1940 ford 1/2 tons.My friends truck has been in his family since new but I purchased mine in 2008.The question I have is how do you remove the outside door handles.It appears that there should be a clip on the shaft or something but with the limited viewing in this area we cannot see a pin or anything that is holding it.If someone has tackled this problem we would really appreciate your help.Thanks Gord
Old 02-04-2009, 10:01 PM
loholland loholland is offline
loholland is starting off with a positive reputation.
Well, I haven't tried it yet but the way I understand it, you hold the inside door handle all the way in the open position and the outside handle should pull out. It may be hard but wiggle it around and it should pull out.
Old 02-05-2009, 07:51 AM
Thanks a million for the advice-I will give it a try this morning and let you if it works.The weather is -19C here today with a foot of fresh snow so inside jobs are good.Gord
Old 02-05-2009, 05:28 PM
40 ford door handle removal
Thanks so much to loholland from Indiana-the advice on how to remove the outside door handle was exactly right-equipped with your information it took all of two minute to remove each door handle.Thanks again
Old 02-07-2009, 12:26 PM
Sorry Gord, but I have to give credit where it's due. There is another member called Elder Rodder that I found by doing a search on this forum about door handles, he is the one that posted this answer a few pages back. You can find an enormous amount of information about these trucks by searching the forum this way.
Old 02-07-2009, 03:40 PM
Additional thanks
loholland informed me that he was passing on information he had found on the site posted by Elder Rodder on removing door handles on the 40 pickup.So many thanks go out to Elder Rodder on this information that worked perfectly.Thanks to both of you.Gord from Ontario
Old 08-11-2009, 11:24 PM
mprsox mprsox is offline
mprsox is starting off with a positive reputation.
Smile Many thanks fm new member
guys, thanks for the advice, I just acquired a 1940 ford tonner in great shape, I was very very lucky.... it is all there, even got some gauges, nees mostly body work, but all original steel, windows, even drip rails intact. feel free to chat w me,
i need to try and get the outside door handles off too!
thanks,
Old 08-12-2009, 08:30 AM
door handle removal
Hello and welcome to the site.The door handles pull out real easy,get someone to hold down on the inside handle and pull the outside handle straight out.Likely have to wiggle them a little bit but no prying ,beating,hammering etc required.Have fun rebuilding that 40.Gord
Old 05-11-2010, 10:43 PM
Elder Rodder's Avatar
Elder Rodder Elder Rodder is offline
Elder Rodder is starting off with a positive reputation.
'40 PU Outside Door Handle Removal
Hi Folks,
Happy to know that my post helped you with your outside door handle removal. Someone at Ford had an interesting mind to come up with that Chinese finger puzzle of a setup. Quite brilliant, actually. I worked a long time, and very carefully, before I figured it out.
Regards,
Elder Rodder
Old 05-28-2010, 06:38 PM
alittle40 alittle40 is offline
alittle40 is starting off with a positive reputation.
Hey ER,
Glad to see that your still on this side of the grass. Got to keep helping those young'ins out. You take care.
CU ED
Old 05-31-2010, 09:44 AM
Hi Little 40,
Yes, the youngsters need a lot of help. They should be born with a Ford "Greenbook" in their hand. I'd like to go back and do it all over again, it's been such great fun. Half way to 69 and still going strong. Hard to imagine our trucks are 70 this year.
How's your PU going? I take a look at your gallery from time-to-time, but haven't noticed new pictures of it. It's time to take another look, maybe I missed something. Take care of yourself, I remember you had some heath issues awhile back that were keeping you from working on your truck.
I should ask you a quick question about the noise in my doors. Do you know how to keep the linkage quiet in the opening mechanism? Mine rattle unless they're in the lock position, and then there's tension on them to keep them quiet. My wife suggested using rubber bands to stop the rattle. I might try that as a last resort. Also, my windows rattle in the open position. If I have them closed from the halfway point they get better, to no noise at all when they're all the way up. There are new runners and felts, but noisy all the same. Only the hooked end and the bent around part at the ends of the runners, the way they were from the factory. Have you ever heard of bonding the ends so they don''t move back and forth? Almost silent running with windows up and handles in the locked position, only the exhaust and wind noise. I'm trying to get that with everything open and unlocked. Seems like a small thing, but at this point in the finished state, it's the next step in the refining process. My rodder buddies said to just get louder pipes. Typical rodders...
Regards,
Elder Rodder
Old 03-14-2014, 12:49 PM
46fordgal's Avatar
46fordgal 46fordgal is offline
46fordgal is starting off with a positive reputation.
I was lucky to have found this thread when I was struggling with the outside door handles. I knew there must be an easy way to remove them. It's amazing how easy it was once I had this information. Thanks!
92 through 96 Chrome wheel help Gord's-Fords 1987 - 1996 F150 & Larger F-Series Trucks 0 09-16-2015 06:17 PM
New ECM needed. Gord's-Fords 1987 - 1996 F150 & Larger F-Series Trucks 7 04-05-2015 07:26 PM
How much paint will I need to paint my truck? Please help Mota Paint & Bodywork 1 02-16-2015 11:13 AM
3 easy steps to eliminating the bounce and sway from airbags Torklift Sheryl Vendor Specials, Discounts, Product Announcements & Group Buys 0 02-04-2015 05:13 PM
need help on understanding a paint mishap Gord4048 Paint & Bodywork 5 02-28-2014 08:24 AM
Tags
04, 1940, 40, antique, door, f150, ford, handle, latch, locks, pickup, remove, removing, truck, windows
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
