Lift Kit ?s
Old 02-03-2009, 03:03 PM
AllenOHara6.0's Avatar
AllenOHara6.0
AllenOHara6.0 is offline
Lift Kit ?s
I have a 2006 F350 diesel and i have a rancho leveling kit on it. Im thinking about getting an 8in lift. Good idea or not? If I go to 8in do i need to get a better drive shaft or longer one? Also any pics of what it would look like with something to compare it to. All ive found are pics of the trucks alone and I cant tell if it'll be high enough. Thanks
Old 02-04-2009, 12:13 PM
ReAX's Avatar
ReAX
ReAX is offline
8" is a lot of lift, considering your going to be putting on another 3" inches of tire too. This is going to put your tailgate up a foot higher, and your going to have to climb up another foot to get in. I think it's too tall to be useful, but you may have other uses.
The stock rear driveshaft might work, it has enough length where 8" up will not be as significant to the length, but you'll probably have angle issues and very little spline engagement. The front will need quite a bit of work, the angle will be pretty sharp. Since you have to replace the front, you might try for a deal on two shafts.
Old 02-04-2009, 09:25 PM
AllenOHara6.0
Thanks so do you think a 6 inch lift would be better or is that still too much?
Old 02-05-2009, 09:21 AM
ReAX's Avatar
ReAX
ReAX is offline
My 4" with 35s is as tall as I would go. The tail gate is a little higher than I'd like when doing some things, but for the most part it works pretty well. It really comes down to what your going to do with your truck.
Old 04-23-2009, 10:38 AM
Chucky Babe's Avatar
Chucky Babe
Chucky Babe is offline
6in would look pretty good and you may not have to change drive lines but make sure you get a drop pitman arm
Old 04-23-2009, 10:22 PM
BigGreenVan's Avatar
BigGreenVan
BigGreenVan is offline
8" is definatly big, you can clock the t-case so driveshafts won't be a concern. if this is your daily driver a 6" and 35's or 37"s on thr right wheels will be a much more user friendly for evryday use.
2002exPSD
10-28-2015 04:46 PM
quincyj34
12-19-2012 12:17 AM
Lowboy44
02-02-2012 05:43 PM
1997f350stroker
33
02-14-2010 06:59 PM
beerformeplz
07-09-2007 06:49 PM
Quick Reply: Lift Kit ?s
