engine trans swap in '52 F-6 - Ford Truck Enthusiasts Forums
Old 02-02-2009, 10:10 PM
F-6Flathead's Avatar
F-6Flathead F-6Flathead is offline
F-6Flathead is starting off with a positive reputation.
Question engine trans swap in '52 F-6
Ok...I have no clue if this will work, but I have a '72 390 with a T-18 trans that I would like to put into my '52 F-6. It currently has the 239 and T-98 trans. I would like to keep the T-98, but can't seam to find and adapter plate for it...anyone know of one available??? I know I'm going to have to put in a new motor mount setup...thats not a problem, but if I go with the T-18, will it sit back far enough for the gear shift to come through the floor. Anyone have any info on this would be greatly appriciated! Pics, threads, anything on anyone doing this mode or similar? Thanks in advance guys!!
Old 02-02-2009, 11:10 PM
havi's Avatar
havi havi is offline
I'll have the Roast Duck
havi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to all
shifter hole will be pretty darn close, but the shifter itself will need to be bent backward away from the dash. I put a Ford 400 and T19 (same thing) in my 48 F1, and it lined up except for the stick itself. Figuring out the clutch might be a different story, though. i swapped out the F1 crossmember for an F2 crossmember, as the tailhousing had the mount right on it. I didn't get pics of the tranny while everything sat in place, sorry. I since then took everything back apart, and went a different direction. Nevertheless, it should be ok. Here's about the last pic I took.
Old 02-02-2009, 11:50 PM
Just thought of this...but I would need a different radiator as well wouldn't I? If so what would work?
52 F-2 Tranny T98 Swap? jazzyndon52 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 01-06-2015 09:22 AM
Synchro trans in an F-4? tinman52 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 07-26-2014 04:42 PM
460 in my '52 F1 Kyles Flathead 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 05-26-2012 04:08 PM
What do I have ? cschulz Clutch, Transmission, Differential, Axle & Transfer Case 1 08-16-2007 09:13 PM
trans swap t98 to t18 moore1960 Clutch, Transmission, Differential, Axle & Transfer Case 3 10-31-2002 08:12 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
