Front Clip Choices
Old 02-02-2009, 09:12 PM
55 M-100's Avatar
55 M-100
55 M-100 is offline
Front Clip Choices
Hey guys I am new here and I am looking for some advice. I have a 1955 M-100 and was wondering what is a good choice for an IFS set up? I am leaning towards a TCI Mustang II setup, but I am not sure if I will buy just the crossmember and use all the suspension and steering from a old Mustang II. Or should I just buy a complete hub to hub setup? I also have 1975 Lincoln Mark IV and I was wondering if I could use the front clip off of it. If you guys know of any other front clips that work let me know. I know that Volare works, but would like to know about other ones. Any help would be greatly appreciated.
Old 02-02-2009, 09:40 PM
sparky's Avatar
sparky
sparky is offline
Welcome.... best bet is to check out the Tech Articles... following link parts 1-11 should answer your questions.....
https://www.ford-trucks.com/article/idx/10/0/
Old 02-02-2009, 10:12 PM
LEckart's Avatar
LEckart
LEckart is offline
Buy the new stuff. The old Mustang II is light weight. The new stuff just improves on that design and is much better for this situation. I can't comment on the '75 Lincoln, no experience there. Good luck.
Old 02-03-2009, 11:02 AM
tacson's Avatar
tacson
tacson is offline
That 75 Mark VII is going to be a little wide for your M100. A 77-79 T-Bird, LTD II, or Cougar would be better. My 55 has a 80-91' Fomoco style Front clip. I like it and wouldnt have any problems recommending it again and again.
Old 02-03-2009, 11:30 AM
49willard's Avatar
49willard
49willard is offline
Dave Holmes, "holmsey" put the Jag IFS under his 55 and "aussie 53" put the Jag IFS under his 53. They are both are driving them.
Old 02-03-2009, 04:47 PM
mechmagcn's Avatar
mechmagcn
mechmagcn is offline
I am running a 87 Town Car IFS in my 53. While not an extremely difficult swap, it is not for the novice or the faint of heart. If done correctly it rides well and handles like a car. Welding skills and some engineering knowledge is a must. My frame was damaged beyond repair from a PO botched Volare IFS, or I would have gone the Jag route as suggested by others.
Old 02-03-2009, 06:23 PM
49willard's Avatar
49willard
Check out this current thread for Jag IFS expereince.
https://www.ford-trucks.com/forums/8...sion-guys.html
Old 02-03-2009, 06:52 PM
55 M-100's Avatar
55 M-100
55 M-100 is offline
Thanks for all of the info guys. Now that I have some direction in the matter it will help make my decision easier.
Reuben
Old 02-04-2009, 02:45 PM
thepitshop's Avatar
thepitshop
thepitshop is offline
never did a lincoln front end but measure both frames, i`m sure it can be done! measuring a bit of cutting and welding and you`ll have a great front end on your truck! and you already have the car so its free!!
Old 02-06-2009, 02:31 PM
79Thunder's Avatar
79Thunder
79Thunder is offline
Hi Rueben, welcome to the board. PM sent.
slaney30
01-26-2013 01:27 AM
Deuce06
10-17-2009 03:08 PM
tacson
12-22-2008 08:45 PM
61Canuck
05-13-2006 08:28 AM
Quick Reply: Front Clip Choices
