Go Back   Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
6.0L Power Stroke Diesel 2003 - 2007 F250, F350 pickup and F350+ Cab Chassis, 2003 - 2005 Excursion and 2003 - 2009 vanSPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 02-08-2009, 09:32 PM
xgatorx1976's Avatar
xgatorx1976 xgatorx1976 is offline
xgatorx1976 is starting off with a positive reputation.
Tim
Is this truck an auto or manual trans?
Have you tried to start it with wd40 in the air pipes?
__________________
Randy
99.5 F350 Regency conversion kit 4x4 DRW
DP TUNER with: nostart,stock,high idle 1300,60t,decel,80e,120,140
Full 4" exhaust straight piped
6637 air filter
  #17 (permalink)
Old 02-08-2009, 11:03 PM
Hiflyer746 Hiflyer746 is offline
Hiflyer746 is gaining momentum as a positive member of FTE. Hiflyer746 is gaining momentum as a positive member of FTE.
its an auto. . . I havn't tried to start it with anything but diesel. If the wd40 trick is like starting fluid. . . I won't use it because the engine should never need starting fluid to run. . . something on it isn't working properly. I'm trying to ascertain why its smoking so much when it does start. Smoking black that is. If anybody has had this symptom and it ended up being a glowplug issue. . . I would like to know about it. I do not think its a glowplug issue. . . except for the fact that the one side is ohming out higher than the other. . . and I do need to research that wiring a little more. . . But the owner started it the other day. . . after being plugged in all night. . . and he said it chugged and smoke black like crazy for five minutes before it finally idled normal. So to me that doesn't sound like a glowplug issue.
Timmy
__________________
Tim
2000 F-350 CC LB 4x4 6 spd Hmax: headgaskets, valve springs and stage II singles. back to H2E, Terminator Big Oil, Dp tuner, CPRX fuel system, oil bypass kit, Ceremetalic clutch, Procomp 6.5" lift, 05 Front end, 37's on 20's. Guages.
Tags
20032007 , bubbles , coming , diesel , fuel , heater , hfcm , kit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
