Go Back   Ford Truck Enthusiasts Forums > Other Fords > Nite, Nascar and Other Limited Edition Ford Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 02-02-2009, 06:01 PM
roadrunner doug roadrunner doug is offline
roadrunner doug is starting off with a positive reputation.
Ford TRAILER SPECIAL??????????
My buddy just found an old truck on his property,it was buried.He said the tailgate has a big piece of stainless or aluminum trim on it and it says trailer special.Any body ever seen or heard of one????1970 ish
  #2 (permalink)
Old 02-07-2009, 09:26 AM
waynaferd's Avatar
waynaferd waynaferd is offline
waynaferd is starting off with a positive reputation.
Hmm. Nope, just camper specials. Unless its a dealer ''special", as in, the dealer had the badge made and added different trim or whatnot.
__________________
Just a little 94 F-150 Flareside, 4.9/5-speed, 4" of Rough Country lift and 35's, with more on its way
And a big ole 67 F-250 Hi-Boy ****under construction*** ( READ: sitting untouched for 2+ years )
I stole my avatar pic!!
  #3 (permalink)
Old 02-08-2009, 05:27 PM
rambuck's Avatar
rambuck rambuck is offline
rambuck is starting off with a positive reputation.
Yeah, there was. It was 70's to early 80's from what I am gathering. Also on the Bronco. It was a little red rectangle that says, "Trailer Special." It came with a 460 and all sorts of convenient options that helped towing then. Now those are standard on trucks, like power steering, brakes, etc. Also it probably had a good towing package for the day. Look up "Ford Trailer Special."
Now that I think about it, I believe my great-grandpa's 150 XLT Explorer Ranger also had a "Trailer Special" badge or the "Camper Special" badge. I can't remember.
  #4 (permalink)
Old 02-08-2009, 05:50 PM
I have seen Camper specials,but never trailer specials.We are going out next wekend to take pictures
  #5 (permalink)
Old 02-08-2009, 06:00 PM
rambuck's Avatar
Ok, sounds cool. Post them up!
  #6 (permalink)
Old 02-09-2009, 08:51 PM
waynaferd's Avatar
^^^^ definately!! ^^^^
__________________
  #7 (permalink)
Old 02-22-2009, 02:02 AM
Vinford's Avatar
Vinford Vinford is online now
1979 Ford F-250
Vinford is gaining momentum as a positive member of FTE.
Ive had a "Trailer Special" badge hanging on my wall for years.
__________________
Ken
2002 F-350
Foil delete , Edge Ev
1979 Ford F-250
1996 Ford F-250
Plus a few more ....................
  #8 (permalink)
Old 02-23-2009, 10:39 AM
Jermafenser Jermafenser is offline
Jermafenser is gaining momentum as a positive member of FTE. Jermafenser is gaining momentum as a positive member of FTE.
Very common package on older pickups. You didn't hit the gold mine. Relax.
They still offer such packages - they only quit advertising it on your truck. Times were/are different.
__________________
Chad
1997 F350 XL 4WD, 351W & E40D
1978 F150 Ranger XLT 2WD, 351M & C6
  #9 (permalink)
Old 02-25-2009, 12:35 PM
Arctic Wolf's Avatar
Arctic Wolf Arctic Wolf is offline
Arctic Wolf is starting off with a positive reputation.
Fifth generation (1967–1972)
Fifth generation
Production start 1967
Production end 1972
Assembly Cuautitlan, Mexico
Dearborn, Michigan, USA
Edison, New Jersey, USA
Kansas City, Missouri, USA
Long Beach, California, USA
Norfolk, Virginia, USA
St. Paul, Minnesota, USA
St. Louis, Missouri, USA
General Pacheco, Argentina
Sao Bernardo do Campo, Brazil
Hapeville, Georgia, USA
Louisville, Kentucky, USA
San Jose, California, USA
Wayne, Michigan, USA
Oakville, Ontario, Canada
Body style(s) 2-door pickup
4-door pickup
Engine(s) 240 CID (3.9 L) I6
300 CID (4.9 L) I6
352 CID (5.8 L) FE V8}
360 CID (5.9 L) FE V8}
390 CID (6.4 L) FE V8}
302 CID (4.9 L) Windsor V8
Another refresh came in 1967 along with a familiar name: the upscale Ranger trim line in addition to the base and Custom Cab trim levels. In 1968, federal regulations required all automotive manufacturers to add side marker reflectors or lights, so Ford redesigned the hood emblems to incorporate reflectors.[3][4] The same year the trucks received larger versions of Ford's FE engine family with the introduction of the 360 and 390 cubic inch engines. Also changed for 1968 were the heater controls, arm rests, interior door handles and window cranks, and the upper trim moulding on models so equipped. Rear side marker reflectors were also added to the lower bed side panels in 1968, per government regulations. The 302 V8 became an option in late '69. The top trim for 1970 was now named Ranger XLT with Ranger, Sport Custom and Custom rounding off the rest of the line. The fifth generation bodies were noted for durability and simplicity of design making them a favorite for restoration.
Some trucks came with an outer flush mounted bed side compartment/tool box on the passenger side only. Trucks from the Fifth Generation can be identified as to year model by their year specific grille arrangements.
After the 1968 models, Ford discontinued the "Low GVWR" versions.
Still available was the Camper Special option, along with the new Explorer Special (a trim package), Contractor's Special(including a behind the seat toolbox and 3/4 ton (F-250) suspension), Farm and Ranch Special, and Heavy-Duty Special. Most of these "specials" from 1967-72 were made in relatively low numbers and are now becoming increasingly difficult to locate.[citation needed]
The fifth-generation F-series was introduced in Brazil in 1971, which remained in production until circa 1992 [5] with a slight redesign and changes in its motorizations.
Models:
  • F-100: 1/2 ton (5,600 GVWR max)
  • F-110: 1/2 ton (4X4)(4,200 GVWR max)
  • F-250: 3/4 ton (7,500 GVWR max)
  • F-260: 3/4 ton (4X4)(4,800 GVWR max)
  • F-350: 1 ton (10,000 GVWR max)
  • F-360: 1 ton (4X4)(6,000 GVWR max)
Engines:
Engine Years Power
240 CID Straight-6 1967-72 150 hp (112 kW)
300 CID Straight-6 1967-72 170 hp (137 kW)
352 CID FE V8 1967 208 hp (155 kW)
360 CID FE V8 1968-72 215 hp (160 kW)
390 CID FE V8 1968-72 255 hp (189 kW)
302 CID Windsor V8 1969-72 205 hp (153 kW)
__________________
  #10 (permalink)
Old 02-25-2009, 12:38 PM
You know your a redneck when you grow trucks other then vegetables. LOL I think the contractors special would be cool with the built in tool box.
__________________
  #11 (permalink)
Old 02-26-2009, 05:19 PM
racsan's Avatar
racsan racsan is offline
1993 Ford Ranger
racsan is starting off with a positive reputation.
ive seen many camper specials, a couple of trailer specials, but thats been about it. wow, 170 hp out of the 300? i only recall it making about 145. course the pollution garbage had alot to do with mid-70's ratings. weird though that a 352 made only 3 hp more than a 302, wonder if it had more torque though? never heard or seen of a f-110, f-26- or a f-360. my favorite series was the '73-79 with the '77 specifically with the 400/C6/4.10's with full-time 4wd. 8 mpg sure, but what a snow-pushing beast!
__________________
'93 Ranger Supercab,4.0L,4x4 5spd-hurst equipped. mile marker manual hubs. "the green machine" http://www.myspace.com/small_dog_trucking
http://www.cardomain.com/ride/3216869
  #12 (permalink)
Old 07-06-2009, 03:59 PM
bduff007's Avatar
bduff007 bduff007 is offline
1977 Ford Bronco
My Garage
bduff007 is starting off with a positive reputation.
They are not too rare. I have a '78 F-250 2WD with the "Trailer Special" package. The package consisted of heavy rear suspension, rear wireing for trailer brakes, X-tra cooling radiator, additional trans cooler, bigger mirrors, dual piston front calipers, wider rear drums, wireing under dash for brake controller, and other little doo dads.
If I remember right the badge on the tailgate was in the shape of the continental U.S. or a rectangle, not sure though.
It was avaliable on Bronco, 150, 250 and 350
  #13 (permalink)
Old 07-11-2009, 05:57 PM
alxsnmr alxsnmr is offline
1991 Ford Bronco
alxsnmr is gaining momentum as a positive member of FTE.
Looks like it had a front sway bar on it too.
__________________
Stock 1978 F250 Custom regular cab 4x4 with 351M and 4 spd.
1991 Bronco silver anniversary, 5.8L EFI, E4OD swapped for C-6, custom trimmed rear fenders finished in rust.
2009 Fusion SE 2.3L 5spd Red/black cloth n leather
  #14 (permalink)
Old 07-11-2009, 06:12 PM
76f350spercamprspeal's Avatar
76f350spercamprspeal 76f350spercamprspeal is offline
1976 Ford F-350
My Garage
76f350spercamprspeal has a very good reputation on FTE. 76f350spercamprspeal has a very good reputation on FTE. 76f350spercamprspeal has a very good reputation on FTE.
There's nothing really rare about the Trailer Special Package.
Wanna see a rare truck,look at mine.
__________________
-With all Due Respect-
--Anthony-- -*~<-76SCS->~*-
*Anthony's Truck Pictures *Anthony's Truck Pictures-2 *Anthony's Truck Pictures-3
Father's Formally owned-67 F250-69 F250-77 F350-93 E350-*--Join The SoCal Chapter *Here*
  #15 (permalink)
Old 07-12-2009, 09:06 PM
Retiredfire Retiredfire is offline
Retiredfire is starting off with a positive reputation.
Red face Special
In 1969 Ford had a Contractors Special with Tool boxes And they had a Farm & Ranch Special .I ordered a Farm & Ranch special in 1969. I had to go to Army so I had sale it. In 1971 I come home and brought a new 1971 .
Tags
1970 , 1976 , 1977 , 350 , 79 , camper , contractors , custom , f250 , f350 , ford , special , sport , trailer , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
