Just realized my tranny has no syncros - Ford Truck Enthusiasts Forums
Old 02-02-2009, 05:21 PM
hellbound_redneck hellbound_redneck is offline
hellbound_redneck is starting off with a positive reputation.
I believe that the 4 speed I installed does not have any syncros. I have never driven a non syncroed trans before, any pointers or tips? I know that you are supposed to double clutch, but have never done it before. BTW reverse is over and back on the pattern.
I know with the older vehicles it is supposed to be an art form to drive them properly.
Old 02-02-2009, 06:08 PM
bobj49f2's Avatar
bobj49f2 bobj49f2 is offline
bobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud of
The shift pattern is the give away, to the right and back. If it were a syncronized tranny it would be to the right and up.
Here's a page I have on my web site that might help:
Shifting a Non-sycro Four Speed
BTW, with the four speed you start out in 2nd gear.
Old 02-02-2009, 07:13 PM
lonestaraggie's Avatar
lonestaraggie lonestaraggie is offline
lonestaraggie is starting off with a positive reputation.
Mine currently has that transmission. It's a bear to drive. I've been driving 18 wheelers with non-synchro 10 speeds for years and can't seem to master a Ford 4 speed. Go figure. I'm rebuilding my truck with the stock 3 speed so I don't have to be as embarrassed grinding gears pulling into the local cruise in...
Old 02-02-2009, 07:47 PM
well currently i can only go around the house with it as i have a fuel pump pumping out of a 1 gallon gas can, so there is no problem moving it if i only use first and reverse... lol
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
