Service Department - Ford Truck Enthusiasts Forums
Washington Chapter Washington Chapter
Join Chapter, Leader: Yahiko
Service Department
Old 02-02-2009, 12:58 PM
Jay Banks Jay Banks is offline
Jay Banks is starting off with a positive reputation.
Service Department
Hello,
Can some one tell me what Service Department is better. Lithia here in the Tri-Cities or Legacy. The reason I ask is because my 2006 F-250PSD is leaking oil, just a few drops now and then. The fan belt also squels, the belt looks like it is in good shape. Iknow the belt is going to cost me extra, because it is not covered under the warranty. If any one has been to either one, please let me know.
Old 02-02-2009, 06:55 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
Don't know off hand. I've had good dealings with Lithia down here, if that helps you any.
The belt squeal might be covered, it might be a tensioner or pulley problem.
Old 02-03-2009, 05:36 AM
Grey 250s's Avatar
Grey 250s Grey 250s is offline
Grey 250s is gaining momentum as a positive member of FTE.Grey 250s is gaining momentum as a positive member of FTE.
Hey, Jay
I bought my rig at Lithia Ford in Tri-Cities after lots of comparison between the regional dealers, including Legacy (used to be Russ Dean). The last service dealings I had with Legacy were several years ago but had no complaints at the time.
I'm under the FORD ESP and take my truck to Lithia for maintenance. As it turns out, I was in there a couple of weeks ago for oil change and transmission flush. I'm glad I paid for the lifetime oil change. At 42k miles, it's more than paid for itself.
Anyway, they noticed a small oil leak. At my next oil change, they will keep the truck and run dye to pin-point the source. If it's the rear seal, a one day job. If it's the bed plate, they said a three day job because they will pull the engine and flip it. I asked if the cab had to be removed to pull the engine. He said he didn't think so for the '06. They take the front end of the truck off instead (grill, radiator, etc) and pull it out the front. While I was there, they had an '08 in the service bay with the cab removed for an oil leak repair.
One day job or three, they said they'd give me a loaner to drive while they have my truck.
I think they are up to 7 qualified diesel techs in the shop. You'll see who they are and each's number of years experience posted on the wall in the service manager's office.
I've got zero complaints about the service at Lithia.
Hope this helps.
(thanks for the "heads-up", Steve)
Old 02-03-2009, 10:02 AM
Thanks for the info, I think I will make an appt. today at Lithia. I bought a Dodge through Lithia back in 2001 and had no complaints with the service. My truck just rolled over 40,000 miles, with no troubles until now.
Thanks!
Service Dept Recommendation F450 Azuretruck 2017 Super Duty 4 09-06-2016 09:51 AM
Fuel Problem in 1984 Ambulance Van Style volunteerlady 1968-2013 Full Size Vans 3 12-27-2015 07:30 AM
Downey Ford Service - CLOSED bpounds S. California Chapter 11 02-02-2009 12:09 PM
2008 6.4 engine/tranny temp gauges Bowstring 6.4L Power Stroke Diesel 8 03-27-2008 08:50 AM
5w20 or 5w30 in 2000 5.4L? DTS419 Oil & Lubrication 5 03-30-2006 10:15 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
change, complaints, dean, depa, ford, forums, lifetime, lithia, oil, russ, service, truck, trucks, washington
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
