Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck SPONSORED BY:
Is F-150 Still King?
  #46 (permalink)
Old 11-04-2009, 09:55 AM
Ringo Fonebone's Avatar
Ringo Fonebone Ringo Fonebone is offline
Ringo Fonebone is starting off with a positive reputation.
I see in this thread there have been some of the usual gang of clowns who say the 302/5.0 was not a truck motor.
Of course, Ford only installed it in their pickups from 1968 to 1996, just 18 years, so How could it be a truck motor?
Those long-lived engines like the 352 (3 years of factory installation) and the 390 (9 years? maybe) were obviously much better, just due to how long Ford installed them for, right?.
Go with the 302.
The only displacement engine Ford ever installed in pickups for more model years was the 300 six.(21 years)
__________________
1927 Roadster Pickup
1964 Mercury M100 project
1983 F150 Supercab
  #47 (permalink)
Old 11-04-2009, 09:58 AM
oops double post
__________________
1983 F150 Supercab
  #48 (permalink)
Old 11-04-2009, 10:23 PM
buckarooranch's Avatar
buckarooranch buckarooranch is offline
1966 Ford F-100
buckarooranch is starting off with a positive reputation.
I'm going to do some more measuring before the absolute final decision. Making motor mounts and trying to work out the front suspension details will be the final decision.
The '66 4x4 has an intergral mount under the transmission/case that really can't be taken out or the front suspension will lose all it's integrity. If I use a "longer" drivetrain, I may not be able to get a front driveshaft by the mount. Hence, using the stock drivetrain may be the simplest/easiest/cheapest way to go.
If I used the 302/5.0, I would not use the EFI, but a carb due to cost and simplicity. I am told that even though my AOD is not an electronic version, there are some electronics it needs to operate, which I was not aware of.
Any thoughts?
  #49 (permalink)
Old 11-06-2009, 11:25 AM
peganit2's Avatar
peganit2 peganit2 is offline
1977 Ford F-250
peganit2 is starting off with a positive reputation.
The 302 aod wont gain much if anything in the milage department. And if you add in the cost of the conversion, you're bucks behind on it. My brothers 89 F250 2wd with a 302 and a 5 spd manual, with overdrive, doesn't vary much from around 12 MPG. Your 65 being lighter might get a little better, but then the auto will take some milage away.
There would have to be another consideration in the equation to make the swap worth your time and money. Going fuelie for better emissions and drivability? Subsidizing your sons future, if you don't pass the cost of the swap onto him? Slightly lighter weight? Auto versus manual, for ease of commuting? There are more viable reasons, but your own wallet will be lighter.
__________________
Project truck "Dirty Beast" BBF Highboy
"Make things Simple, Not Simpler" - Albert Einstein
  #50 (permalink)
Old 11-06-2009, 11:45 AM
peganit2's Avatar
1977 Ford F-250
As far as the 302's power, they are far more than adequate.
My brothers truck is a fuelie with that sweet truck tuned intake manifold and it has no issue with any load you put on it. And that's the the real measure of a truck.
I had the bed and a 3/4 ton pick-up truck based trailer, (they're very heavy) full of aggregate for concrete, and the loading dock was very poor, uphill, with the rear tires in foot deep ruts. I was worried when I pulled into it, but no need, the little 302 and the truck didn't break a sweat. Might as well have been empty as far as the engine was concerned.
A fuelie 302 MAY be going into my dads 65 F100 SWB. A manual for sure though.
__________________
  #51 (permalink)
Old 11-06-2009, 02:08 PM
EricJ EricJ is offline
EricJ is starting off with a positive reputation.
Quote:
Originally Posted by bertha66 View Post
When I went from the 352 to a 390 in my 66 4x4, the MPG went up. The engine works less, better wieght to hp ratio. I have squessed 15-17mpg out of it.
What are you running for gears? I just swapped a 79 4x4 chasis into my 65 352, it was getting 13mpg with 3:25's in the 2wd, now it's getting 10mpg with 3:50's and 4wd.
I have 2 390's on the floor that are both good and was thinking of swapping one in, but I may swap the gears out first and see what I can get. I haven't researched gears yet but I have a set of 3:00's I can put in the rear to try out. Any thoughts?
  #52 (permalink)
Old 11-07-2009, 09:32 AM
peganit2's Avatar
1977 Ford F-250
The 65 F250 2WD with a 390 and a t18 4 speed that I use to have got 15 MPG highway, and I certify it. I do believe, but I am not positive, that it had 3.91 gears in it. It accelerated very "freely". The rear end is still available for inspection so I could find out for sure if anyone is interested. Might take a while though.
__________________
  #53 (permalink)
Old 11-07-2009, 08:51 PM
Red2003XLT Red2003XLT is offline
Red2003XLT is starting off with a positive reputation.
Doesn't a 300 I6 use the same mounts as a FE motor?
Might solve all of the OP problems.
__________________
Ranger 2003 XLT 3.0 V6 auto Pure stock 24,000 miles
  #54 (permalink)
Old 11-07-2009, 08:57 PM
peganit2's Avatar
1977 Ford F-250
Nope......
__________________
  #55 (permalink)
Old 11-07-2009, 09:00 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation
Quote:
Of course, Ford only installed it in their F Series pickups from 1969 to 1996, just 17 years, so how could it be a truck motor?
1969/79 F100, 1975/79 F150 302 use the exact same engine supports (towers, perches) as 1977/79 F100/350 2WD 351M/400.
__________________
Bill / Retired Ford Partsman (1962/97) / SoCal Chapter Member.
Part Number Research: Trucks: 1928/2000 // Cars: 1928/79.
1934 Packard V12 Convertible Victoria // 2008 Fusion S // 2008 Edge SEL.
  #56 (permalink)
Old 11-08-2009, 06:27 AM
jowilker's Avatar
jowilker jowilker is offline
1966 Ford F-100
jowilker has a great reputation on FTE. jowilker has a great reputation on FTE. jowilker has a great reputation on FTE. jowilker has a great reputation on FTE.
Aaaah Bill, Shouldn't that be 27 years???
I will agree that it was an engine in a truck, but like step sides, big blocks, etc., it aint a TRUCK MOTOR.
John
__________________
In the cool still quiet hours of night, you can hear chevies rusting away.
  #57 (permalink)
Old 11-08-2009, 08:06 AM
Ford Parts Guru
Of course, Ford only installed it (302) in their pickups from 1968 to 1996, just 18 years, so How could it be a truck motor?
What he said...
I knocked off a year because 1969 was the first year for the 302, not 1968.
So...from the looks of things...neither one of us can add worth a damn!
__________________
  #58 (permalink)
Old 11-08-2009, 08:07 AM
peganit2's Avatar
1977 Ford F-250
My wife is gonna be excited to hear she's 10 yrs younger than she's been led to believe, since she was born in 1968! Me too since I don't have to trade her in now that she has 9 yrs to hit 40!
Sorry Joe, I don't understand your comment, " ... but like step sides, big blocks...". Can you explain?
__________________
  #59 (permalink)
Old 11-08-2009, 09:40 AM
peganit2's Avatar
1977 Ford F-250
Sorry, I meant John.
__________________
  #60 (permalink)
Old 11-09-2009, 01:40 PM
bertha66's Avatar
bertha66 bertha66 is offline
1966 Ford F-100
bertha66 is starting off with a positive reputation.
Sorry, been a very long time sense I looked at what gears are under the truck, so I don't know. But I use 3.00 in a 64 Galaxie, they seem to be good for hiway speeds and gets better MPG than the 3.25's that were in her before.
__________________
Allen D
1966 F-100 4x4 with 390 GT engine
1990 Areostar 2wd XLT ext
1980 Bronco with 460
1964 Galaxie 500 with 428
Oregon Chapter Member: To join the Oregon Chapter, click HERE
Tags
1966 , 1977 , 2wd , 390 , 4x4 , 66 , 68 , cheapest , f100 , f250 , ford , lower , nv4500 , pups , swb , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
