1953 f-100 gauges in a 1950 f-1? - Ford Truck Enthusiasts Forums
Old 02-01-2009, 10:50 PM
joefordman joefordman is offline
joefordman is starting off with a positive reputation.
I have been told conflicting info from a couple of friends. one said the 53 gauges will fit in a 50 ford pickup, and another said they won't. does anyone have a difinitive answer? thanks. joe
Old 02-02-2009, 01:59 AM
Julies Cool F1 Julies Cool F1 is offline
Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.
The internal works of all the gauges from 48 to 55 , and possibly 56 , less the faces - are the same. The gauges are assembled in about three layers - a mounting plate on the back of a round gauge body, then a face. The mounting brackets are generally the same but sometimes need to be flip flopped to be mounted in the cluster of another vehicle. in the 51-52 they are diagonally mounted. Possibly horizontal or vertical in 48- 50.
Sending units are the critical part (for the 56 12V equation) -matched to the gauges (all the same/interchangeable from 48-55 per instrument I think - Number Dummy can confirm or deny) and they are the same for both instruments and idiot lights 48-55 - that's confirmed.
So, you could take a 53 temp gauge and sending unit and install it on your 50 by just changing the face, and installing the original mounting plate on the back and it will be ok. Of course there are exceptions which I'm sure folks will throw in here. We can address those as they come up.
OBTW did you know that modern mecahnical and electric gauge works can be inserted into the older gauge bodies and used? My oil pressure and temp are modern mechanical gauges, mounted in the original cases with the original faces and mounted in my stock gauge cluster on my 51 F1. You'd never know th ediff, except the temp gauge reads accurate temp when th eignition is switched off instead of going up to "H" as a stock electric gauge would.
Julie
Old 02-02-2009, 02:01 AM
Site bumble creating double post - sorry,
Julie
PS: Weird
FREE GAUGES HILLBILLY BOB 1948 - 1956 F1, F100 & Larger F-Series Trucks 56 12-22-2016 02:12 PM
Temperature Gauge not working F-ReV 1987 - 1996 F150 & Larger F-Series Trucks 3 07-16-2016 12:58 AM
dummy guage changeover date? muscletruck7379 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 11-18-2014 07:50 PM
1981 F100 Custom - Gauge cluster problem my996duc1 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 14 09-23-2014 12:08 PM
New location for non-OEM water temp sender kabcpapc 1997 - 2003 F150 3 09-06-2014 04:53 PM
Tags
1953, f100, guages, original
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
