Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.0L V6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 02-01-2009, 08:46 PM
stephen223 stephen223 is offline
stephen223 is starting off with a positive reputation.
Head Problems?
04 Ranger 3.0L Gave 300,305 and 316 codes at 70K miles. After replacing injector, plugs, wires, and the idle sensor, compression test showed it was the # 5 cylinder. Got the heads rebuilt and was told it was sunken exhaust seats. Problem solved until this week.
Now 108K miles and codes 300,301, and 316 appear. Slight rough idle and it feels like the engine is holding back around 2000 rpm.
Any suggestions? Am I the only one having problems with the heads every few years?
Thanks!
  #2 (permalink)
Old 02-16-2009, 05:01 AM
blue beast's Avatar
blue beast blue beast is offline
blue beast is gaining momentum as a positive member of FTE. blue beast is gaining momentum as a positive member of FTE.
Get a vacuum gauge or mity vac tester and see what it shows. Performance probe has
a tutorial to show you what the needle will look like for different problems (bad rings,
valve seat, weak springs, plugged exhaust etc.) Look under diagnostics in the sitemap
and read all the way through it then get the vac gauge and test your manifold vac readings. Also don't forget gas line dryer I would put at least 2 bottles in on 1/4 tank
or so, Water in the fuel will give a midrange deadspot!!
__________________
86 fs bronco 302 auto 33x12.50 at rusty but trusty!
91 ford probe lx mtx The mighty vulcan 3.0
Before posting fuel related problems Run a couple of bottles of dedicated gas line dryer through IT!!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
