Loss of power & missing - Ford Truck Enthusiasts Forums
Old 02-01-2009, 07:10 PM
isdave isdave is offline
isdave is starting off with a positive reputation.
Hi Driving home from work the truck started to run rough and no power.I have read up on the uvc problem so when the truck was running I pulled off the passenger side plugs on at a time and there was no difference.There was a difference on the driver side when I did it.I checked the plugs they were not burnt or melted and I took off the valve cover and everything looked fine.Is there something that controls a whole bank of injectors that I am missing thanks
Old 02-01-2009, 08:01 PM
excavator's Avatar
excavator excavator is offline
excavator is gaining momentum as a positive member of FTE.
Did you look at the pins for being burnt or melted in the connections?
There is the IDM (injector drive module) that sends the signal to each bank and it could have water inside and it will cause havoc and could shut down entire bank. It is located on the drivers inner fender well and is held on with a few bolts. You could take it off and shake it for water sound
Old 02-01-2009, 09:52 PM
c00nhunterjoe's Avatar
c00nhunterjoe c00nhunterjoe is offline
c00nhunterjoe has a very good reputation on FTE.c00nhunterjoe has a very good reputation on FTE.c00nhunterjoe has a very good reputation on FTE.
the key when pulling each harness off is when you remove one and there is no change, that is the culprit, when you pull a harness and it gets worse then you know that injector was firing untill you removed the harness
Old 02-01-2009, 10:47 PM
thanks I will check the IDM tomorrow and let you know
Old 02-03-2009, 11:45 PM
got the news today from my mechanic IDM producing the problem.The dealership wants 1600 for remaned one I can't believe the cost.Phoned around and found one for 575 ouch!!!!
Old 02-04-2009, 06:40 AM
tjbeggs's Avatar
tjbeggs tjbeggs is offline
tjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to all
Quote:
$1600!!!!!!??????? I have never heard of one that high!! $575 is still higher than I would pay. Unless your in a real big yank to get the truck (we usually are!) check out auto computer exchange on ebay. Just search IDM and you find them. Great prices and products.
Old 02-04-2009, 04:26 PM
excavator's Avatar
1600 dollars
Hope they are including the engine
Old 02-04-2009, 05:02 PM
Action4478 Action4478 is offline
Action4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputation
I got a new one on ebay for 225 + shipping ..
Hey ....Jim ...
Way too quiet...
Old 02-04-2009, 05:07 PM
excavator's Avatar
Whata u say Rick
Yup quiet
Old 02-04-2009, 06:46 PM
97biostroke's Avatar
97biostroke 97biostroke is offline
97biostroke is starting off with a positive reputation.
I bought one last week on ebay, a 120V IDM with a one year warranty for just under 200 after shipping. It was something like Crites Cores from Indiana. Pretty good deal i thought.
Old 02-04-2009, 09:40 PM
I live in Canada for what ever reason We pay more.I was quoted 1608 at the dealership and my buddy works in ford parts at the local dealer and could get it for 1300.I was lucky to fined one for 575.through another parts guy
Old 02-09-2009, 07:46 PM
Thumper96F250 Thumper96F250 is offline
Thumper96F250 is starting off with a positive reputation.
Hi guys I believe I'm having the same problem. It seems that I'm losing the a hole bank. Not sure what side. When disconnecting the harness from UVC connection outside the cover. Do I have the engine running or not? I know it's high voltage so I'm assuming to have engine off and afraid if running it may mess up the PCM. Am I thinking right? I've also been looking for the proper way to firgure out my problem from start to finish.
My check engine light comes on and the truck won't hardly run it won't pull itself on flat ground. Then it clears up. Then shortly later it does it again. And now it's trust staying that way.
I've replaced the CMP, fuel filter, oil and filter. Cleaned the battery cables and have made sure that the batteries are fully charged.
I was going to start with checking the connections at the valve covers and then the ICP and then to the IPR.
But I can't find the proper way to check all of these. I have no scanner but had it checked at Advance Auto but no codes found. It also didn't seem like they knew what they were doing.
I have the regular tools like wrench's and socketts and DVOM but no pressure gauges.
Any info would be great. Oh I have 96 F250 7.3L
Thanks,
Thumper
Old 02-09-2009, 09:05 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Thanks,
Thumper
For me, same story, different time. My truck would hardly pull itself. The guys on here told me to check the four connections at the VC's. I reported back and said none of them was burnt. Someone, I forget who it was, told me in no uncertain terms to "look again"!!! I used a magnifine glass. I did and sure enough there it was, a burnt pin. I was stranded but within walking distance of a Ford dealer and got a new harness. Unplug the connections one at a time with the engine running to see if it makes a difference in the way it sounds or vibrates. It won't shock you or hurt the PCM. Mine didn't throw any codes.
Old 02-09-2009, 09:18 PM
Thanks oldbird for the info I will check it tomorrow and reply back what i find.
Did you have to replace the harness outside or inside the valve covers?
Old 02-09-2009, 10:09 PM
I lost the whole bank and I unplugged the harness connectors one at a time to reconfirm they were not working while the truck was running.My IDM was the problem it did have water in it.I never had my check engine come and I had no power either.
Trailer Wiring electrical gremlins sammie0126 1997 - 2003 F150 46 12-03-2013 05:10 AM
right head has no power? 77'FORD_man 1973 - 1979 F-100 & Larger F-Series Trucks 54 03-30-2013 02:41 PM
p0354 misfire stuemany 1999 to 2016 Super Duty 4 02-19-2013 05:34 PM
Runs rough, 97 f350, IPR or ICP? andercontracting 1994.5 - 1997 7.3L Power Stroke Diesel 9 09-30-2012 02:39 PM
Strange missing and blue smoke from 91 4.0 91ford_ranger Ranger & B-Series 12 09-29-2004 09:04 PM
Tags
73l, atlanta, idm, loss, oriellys, power
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
