Starter Issue. - Ford Truck Enthusiasts Forums
Starter Issue.
Old 02-01-2009, 06:40 PM
hellbound_redneck hellbound_redneck is offline
hellbound_redneck is starting off with a positive reputation.
Starter Issue.
I have put a 6 volt battery in my F-1, and when I try to start it the starter just spins. I am thinking that the battery may not have enough of a charge to kick the bendix in, but maybe someone has some other things to check?
Thanks for the help.
Old 02-01-2009, 07:00 PM
1955effie's Avatar
1955effie 1955effie is offline
1955effie is starting off with a positive reputation.
yes , i agree make sure that your battery is at full charge . if that checks out you might have a bendix that may be sticking . you may have to take the starter out and clean the bendix drive . good luck ....
Old 02-01-2009, 09:02 PM
Fresh new battery kicks it over, so that was my issue. now I just need to make it so the tank and the carburetor are connected... currently i am using a 12volt pump with battery to draw fuel out of a 1 gallon gas can and push it to the carb.
Old 02-01-2009, 09:33 PM
55 f350's Avatar
55 f350 55 f350 is offline
55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold
my old f-4 did that and the starter bendix took a dump . the new owner had the starter rebuilt and fixed the electrical gremmies and he's driving it . so i'd be willing to bet bad bendix .
Old 02-01-2009, 09:39 PM
I am actually inclined to believe the battery that i had in it was no good anymore. the date code was only about 15 years ago, and it has been sitting for 10 of them.
issue with starter g.logistics Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 12-17-2014 10:02 PM
2008 Expy Battery Good/Starter Bad??? pooneee 2007 - 2014 Expedition & Navigator 1 01-07-2014 02:46 PM
Battery cable sizes Frankiea87 6.0L Power Stroke Diesel 2 12-26-2013 05:40 PM
Can loose battery connectors damage a starter? quiacato 1999 - 2003 7.3L Power Stroke Diesel 6 03-08-2011 11:16 PM
Starter wont disengage kjb304 1997 - 2003 F150 2 08-31-2008 09:50 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
