abs light
Old 02-01-2009, 04:44 PM
scrufff's Avatar
scrufff
scrufff is offline
abs light
Hello,,will a low voltage battery cause the ABS dash light to stay on??I went out to my truck today,,and went to start it,,click,,click,,click,,charged batteries for about three hours,,started truc,,now ABS light stays on. I think the batteries are done,,but still trying to figure out the ABS light
Old 02-02-2009, 07:56 AM
Lazy K's Avatar
Lazy K
Lazy K is offline
What truck is it?
Old 02-02-2009, 10:38 AM
scrufff's Avatar
scrufff
scrufff is offline
the truck is an 04 f350 diesel dually supercab
Old 02-02-2009, 12:17 PM
Lazy K's Avatar
Lazy K
Lazy K is offline
Sounds a nice rig. I thought it may have been an earlier truck, don`t know much about the late model stuff. However anything is possible, the computer may have seen the low voltage as a fault and stored a code. You may need a code reader plugged in to clear the code and put the light out. You may also want to post this on the "HD and SD" page as someone there could well have come across this before. Hope you get it solved.
Old 03-07-2009, 10:27 PM
agreder's Avatar
agreder
agreder is offline
abs light
Hey SCRUFF did you ever find the problem with your truck. Mind did it today so if you did can you point me the right way thanks.
Big Sky
11-14-2013 03:36 PM
Aussie BrianB
Australia Chapter
07-26-2013 09:56 AM
Socal20
Electrical Systems/Wiring
06-23-2008 07:16 PM
phydough
1999 to 2016 Super Duty
09-09-2006 02:04 PM
samahi72
02-23-2006 03:50 PM
Quick Reply: abs light
