5.0 engine - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
5.0 engine
Old 02-01-2009, 03:38 PM
PVT-CHURCH PVT-CHURCH is offline
PVT-CHURCH is starting off with a positive reputation.
5.0 engine
I have a 89 f150 has a 302 in it i plann on pullin the 302 out and puttin a 351 in it. so would it be possible to put the 302 into my ranger? ive heard that you can do this if you relocate the battery and possibly the oil filter but i wasnt sure since my ranger is fairly newer is this still true?
Old 02-01-2009, 04:35 PM
Old93junk's Avatar
Old93junk Old93junk is offline
Old93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputation
Little more info, what year is the Ranger?. 302 swaps are easy in 83-92s, Newer Rangers, I couldnt say.
Old 02-01-2009, 04:44 PM
racsan's Avatar
racsan racsan is offline
racsan is gaining momentum as a positive member of FTE.racsan is gaining momentum as a positive member of FTE.
it could be done, alot of work and its going to be more difficult to do certian maintenence stuff like changing spark plugs. a 302 isnt much more horsepower than a 4.0 ohv though, and im sure it weighs quite a bit more. but to each his own, dual exhaust sure sounds better on a V8.
Old 02-02-2009, 09:11 AM
my ranger is a 2001 with a 3.0 in it
Old 03-22-2009, 05:58 PM
MoToRNecK MoToRNecK is offline
MoToRNecK is starting off with a positive reputation.
Well the 302 only weighs about 100 pounds more than the 2.9L
Old 03-22-2009, 06:18 PM
wendell borror wendell borror is offline
wendell borror has a great reputation on FTE.wendell borror has a great reputation on FTE.wendell borror has a great reputation on FTE.wendell borror has a great reputation on FTE.
Sure. 302's in rangers a real common swap these days, James Duff sells conversion parts and kits to make it easy. As far as I know the battery doesn't have to be relocated, the oil filter might. If so, James Duff will have the relocation parts.
Old 03-22-2009, 06:25 PM
lew52's Avatar
lew52 lew52 is offline
lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.
Quote:
..They make all kinds of kits for the 302 in a ranger...Put a 302 in a ranger will whip a 4.0 anytime...Lew
Old 03-22-2009, 08:45 PM
sfcwoodret sfcwoodret is offline
sfcwoodret is starting off with a positive reputation.
A modded newer 4.0 will beat a stock 302. Been there done that! The new 4.0's are easy to mod out and rev high. With a decent set of gears,tuned,CAI,flowmaster, and some 15-16" performance tires, a 4.0 will run like a scalded dog. I know!
Old 03-22-2009, 10:53 PM
Yeah, the 4.0 sohc about = a stock 302 in hp, the 302 has a little more torque. With the aftermarket for the 302, it isn't hard to get 400 hp out of them. A 4.0 sohc with a cai, cat back and bama engine programer will run with a stock 302 all day, at least part of the day he he.
Old 03-23-2009, 04:55 AM
lew52's Avatar
Most of the swaps i have seen have been the 302 HO mustang motor.Will the truck motor fit with the big truck intake ??.With a lightly built 302 HO they run great..I have never driven a modded 4.0 but i do know what a modded 5.0 HO will do ...
Old 03-23-2009, 05:33 AM
I've only seen mustang swaps as well, I couldn't say about the truck motor.
Old 03-23-2009, 05:49 AM
I would rather go with the 351 for my truck just havent decided fully yet!
Old 03-24-2009, 10:08 PM
DesertStorm's Avatar
DesertStorm DesertStorm is offline
DesertStorm is gaining momentum as a positive member of FTE.DesertStorm is gaining momentum as a positive member of FTE.
A 302 swap isnt too bad to do if you are gonna use a carbed version, EFI is a pain.
Tags
50, engine, ford, rangers, wheighs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
