Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 02-01-2009, 06:43 AM
doubledown11 doubledown11 is offline
Garage is empty, add now
doubledown11 is starting off with a positive reputation.
07 Expy Driver's Seat Issue...help please
I just bought an 07 EB Expy 4x4 and love it. It seems to have a couple of issues I'm trying to work out. Just got the vehicle yesterday. When you turn off the vehicle the drivers seat slides back automatically to make way for exiting. I came back to get somethig out of the truck and heard a click-click noise in the cabin. It would "click-click" then pause for a couple seconds, then "click-click" again. It just kept doing this. I found the noise was coming from under the drivers seat. I bumped the seat forward button and the noise quit. This happened one other time yesterday. I kept checking every time I got out of the car but it appears to be an intermittent issue? Anybody have any ideas what is happening of any fix. I understand this is electrical in nature, but unfortunately I am not.
  #2 (permalink)
Old 02-02-2009, 01:20 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
The gears may have stripped that move the seat forward. Try moving the seat all the way forward and go through the back door and look at the track as you move the seat to see if you can locate the clicking sound.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #3 (permalink)
Old 02-02-2009, 08:27 PM
Gevans17 Gevans17 is offline
1998 Ford Expedition
Gevans17 is gaining momentum as a positive member of FTE.
you're screwed if the seat track is jammed
  #4 (permalink)
Old 02-02-2009, 08:34 PM
This is different. It isin't coming from the track but maybe from the switch or a relay under the seat. It sounded like when you slide the button to move your seat and it first clicks on, then when you let it go it clicks off. That's the sound it makes, only no one was sliding the button and it was just clicking twice, pausing, then clicking twice. It was definately an electrical noise, not mechanical. I've been listening for it but it has only happened twice out of 10 or 15 entry and exits.
  #5 (permalink)
Old 02-03-2009, 10:29 AM
berry1234's Avatar
Is the seat working regardless of the noise?
I know when the seat is moved to the full back position, it stops, you push the button again and then goes an extra inch or so. That is a design flaw. Maybe the easy entry feature is pushing the seat all the way back.
__________________
  #6 (permalink)
Old 02-04-2009, 06:53 AM
Yes it is, this is hard to explain. Everything works as it should. It was just a switch or relay that was stuck cycling on and off. It was not affecting the movement of the seat or anything. I'm just afraid it could happen again and drain my battery or cause other electrical gremlins. The seat does the auto exit when I turn off the car. But the times it has had the problem, I came back to the truck and it SOUNDED like the seat was stuck trying to move forward or back with a pause in between. Physically moving the switch a little made it stop.
  #7 (permalink)
Old 02-17-2009, 03:41 PM
Issue hasn't happened in almost two weeks now. Must've run over the gremlin when the seat was powering forward and squished the little bugger. Knock on wood
  #8 (permalink)
Old 02-25-2009, 02:34 PM
rbarbot2 rbarbot2 is offline
rbarbot2 is starting off with a positive reputation.
Have you tried setting the pre-set seat positions? When you unlock the door with one of the two transmitters, the seat will go to the programmed setting when you get in. Press SET, then #1 or #2.
Maybe your seat is set to a bad spot and you just need to move it slightly.
  #9 (permalink)
Old 03-27-2009, 08:24 AM
ExpyBob ExpyBob is offline
ExpyBob is starting off with a positive reputation.
There was a TSB issued for this some time ago.
I had it. They replaced my seat sensor or something and it's been fine since.
__________________
Bob
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
