Well I just about got the box off my 79.
Now all I need is another box or a CUSTOM MADE DECK!
The blue truck is my latest beater.
Its actually a pretty decent old truck after I get looking at it.
Is the red one in the pic, the one you want me to build the deck for?
If so can you get me some frame width measurements inside and outside.
And gap using a long level, from lowest frame point to the top of the hump in it. And lastly how much higher than the hump the bottom of the deck needs to be to clear the tires at full suspension compression.
I can build 95% of it from those measurements, and knowin where the gas fill spout needs to be located, and what the overall deck length, width needs to be, and what the decking material is.
Say 2x8's, steel plate, plywood or whatever you want the deck to be.
If i recall right, you said you were going to wire it yourself????
