Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > Flathead V8 and Flathead 6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 02-01-2009, 03:06 AM
OldSchoolRodz OldSchoolRodz is offline
OldSchoolRodz is starting off with a positive reputation.
Question Fuel Delivery?
K Fellers;
I was breaking my build budget trying to build my original Y with vintage speed parts; so when I found a rebuilt 53 Chassis / Flattie for cheap, I decided to drop my 55 F100 cab and bed on it to try to get her on the road.
I'm new to Flatties. This engine had been sitting indoors a few years in the truck since the rebuild, and gas had varnished up the old Carbs fuel bowl / float. I replaced the Carb and fuel pump with an NOS Carb and good quality USA made pump before I tried to start it.
I started her up and she ran fine; but to keep her running, I had to feed the carb thru the air horn. Doesn't seem to be pulling enuff gas from the tank, or pushing enuff fuel to the Carb.
I've come up with a couple ideas / possibilities maybe one of you experienced Flatsters can reality test.
I've considered two possibilities; that the old gas settled in some low spot in the metal gas line and gummed it up / partially obstructing gas flow or, have I read somewhere that there's a pushrod that rides on a cam lobe that can wear out of tolerance and reduce fuel flow?
Keep it Kool, Keep it Old School! Thx, David
__________________
Workin this Grrrl, stiffed her Chassie with a 49 X-member N dropped her skirts. Kustom tin, visor, spots, Buick stainless, Hudson taillights, racked with Caddy dagmars, draggin a 1-off Kaiser Continental Kit. Rollin a 53 Flattie on Overdrive N all the Mojo I can squeeze out of her. She's high maintenance, needs sum flat N glossy but hey; classy dont come cheap N cheap aint classy.
  #2 (permalink)
Old 02-01-2009, 04:31 PM
tinman52 tinman52 is offline
tinman52 is starting off with a positive reputation.
Most likely you have debris in tank,try to blow back thru line w/ low pressure air w/ gas cap off. May also be fuel pump. New ones are all made in china and most are junk right outta the box. Electric pump maybe? Also check needle/seat in carb inlet,may be stuck. Let us know what you find. T/M
  #3 (permalink)
Old 02-02-2009, 10:19 PM
Snowking's Avatar
Snowking Snowking is offline
Hail to the king baby
Snowking has a good reputation on FTE. Snowking has a good reputation on FTE.
Remove the fuel line close to the carb, crank over the motor and see what you have squirting out but yes it is always a good idea to clean the fuel system lines and tank, maybe try hooking up a jerry can to your fuel pump see if it runs off that.
__________________
2001 Ford F250/ V10 4x4 1969 Ford F100/ 300
1967 Ford F100/ 352 4spd 1957 Ford F250/ 292
1952 Ford F1/flathead 1950 Mercury M135
1949 Mercury M47 1947 Mercury half ton
  #4 (permalink)
Old 02-03-2009, 11:28 AM
I have a weekend project! If I'm gonna I start pulling fuel lines, I should make sure the bottom of the tank is clean. It a nice rust / dent free tank that looks like it was replaced at some point. What can I use to clean any varnished gas that settled in the bottom of the tank while it was sitting, while I'v got it apart? Thx, David
__________________
  #5 (permalink)
Old 02-06-2009, 10:09 PM
I used laquer thinner in mine, about 2 gallons. Let it soak for a while, then slosh it around,drain it. Repeat. Mineral spirits are a lot cheaper, but don't have as much "bite". Or take it to a radiator shop and have it cleaned $$$. Good luck. T/M
  #6 (permalink)
Old 03-03-2009, 08:19 PM
effie_man's Avatar
effie_man effie_man is offline
Fatty driving the Flatty!
effie_man is gaining momentum as a positive member of FTE.
do the jerry can thing to find out if its the pump (maybe the diaphram is dried out), if not the pump then id start checking lines back to the tank. the psuh rod for the pump could be worn out a little bit, Ive hears that a little trick is to glue a piece of leather at the end of the rod to take up the slack from it being worn
__________________
Chris
53 f100 Custom Cab
04 F150 STX 4x4
  #7 (permalink)
Old 03-04-2009, 08:59 AM
petey shoes petey shoes is offline
petey shoes is starting off with a positive reputation.
if carb was varnished up, then fuel lines are also gummed up. once tank is clean, run new line.
__________________
42 1.5 ton marmon herrington all wheel drive
  #8 (permalink)
Old 03-05-2009, 12:35 AM
Thx, thats what I was thinking! Believe I just need to pull the tank, replace the lines... come spring.
Keep it Kool, Keep it Old Skool. David
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
