Engine swap from a 1984 F150 302 - Ford Truck Enthusiasts Forums
Old 01-31-2009, 07:39 PM
stressfactor03 stressfactor03 is offline
stressfactor03 is starting off with a positive reputation.
Exclamation Engine swap from a 1984 F150 302
Don't know if you will be able to answer this, but i wanna check the compatibility Of this 302 engine from a 1984 for my 1994 Both are 302 the '84 has a carburetor mine is EFI ( i know the intakes will need to be changed,and also the water pumps on the '84 will need to be changed, unsure of the timming cover.) or if i will be able to use my electronics EI: Sensors on the older style 302.........
The transmission is a AOD Overdrive unit and the truck is 2wheel drive.
Rebuilding this engine (In 1994) wont be happening has three rods knocking to come out......doesn't smoke tho so if i need to use the heads to help the conversion over i would need to know that as well....
Years ago i would have been able to answer my own Question but i haven't dealt in fords in a long time now............
Don't have alot of money but i found a decent running 302 for 100 bucks
Thanks for any help on this.
Mike
Old 01-31-2009, 07:54 PM
Old93junk's Avatar
Old93junk Old93junk is offline
Old93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputation
Keep looking for a FI 5.0 from a 94-96, then its just plug and play! Way to much work to put that carbed 302 in. Save yourself a headache.
Old 01-31-2009, 08:10 PM
Ok Thanks.........dont need any head aches right now
Old 01-31-2009, 08:41 PM
70torino429's Avatar
70torino429 70torino429 is offline
70torino429 is starting off with a positive reputation.
if you do decide to use that 84 engine you will need to change the timing chain cover, i had to do this when i swapped a 85 302 into my 1991. other than that it wasnt too difficult to swap everything over. all the sensors carried over with my 85 not sure if they would with a 84 but would recommend taking pictures off the electronics in the 94 before swapping everything out so you know exactly how it was all setup
Old 01-31-2009, 10:47 PM
Conanski's Avatar
Conanski Conanski is online now
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
That motor will work, the block and head dimensions never changed on the 302 so the intake, timing cover and water pump, accessory brackets and everything else you strip off your motor will bolt right on. And yes it will run on the EFI system too, just won't be quite as powerful as your '94 when it was in good running order.
Motor questions? 302 Charlesmax90 1978 - 1996 Big Bronco 4 08-28-2016 08:22 PM
1961 CF700 Engine Info CF700 1961 - 1966 F-100 & Larger F-Series Trucks 2 05-09-2016 08:56 PM
1994 ford f250 302 mods 81fordf100 1987 - 1996 F150 & Larger F-Series Trucks 0 06-30-2015 02:14 AM
Wiring Harness Issues With 302 to 351 Swap GA_Forester 1987 - 1996 F150 & Larger F-Series Trucks 1 10-02-2014 08:55 PM
302 heads HELP PLEASE!!!!! jasonw302 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 04-05-2005 01:52 PM
Tags
1984, 302, 460, engine, f150, moter, swap, swaps
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
