Rear Leaf Springs for 52 panel - Ford Truck Enthusiasts Forums
Old 01-31-2009, 06:13 PM
52 panel's Avatar
52 panel 52 panel is offline
52 panel is starting off with a positive reputation.
I'm in the market for a set of rear springs that will fit my 52 panel. Any information regarding compatiable swaps appreciated.
Old 01-31-2009, 07:28 PM
kcb37's Avatar
kcb37 kcb37 is offline
kcb37 is starting off with a positive reputation.
You might try asking a spring shop.
You may have to take measurments of yours, but I would assume they would be able to tell you what would fit. They may even have some they took off of something for a lift or drop. You might price some to they may be cheaper then you think.
Old 01-31-2009, 07:45 PM
john smith jr john smith jr is offline
john smith jr is starting off with a positive reputation.
I found a decent used set for my rear springs on another forum. Got the front springs at JC Whitney, US made,....new with bushings already pressed in. Got the other bushings, pins ,lock pins, U bolts ect at Dennis Carpenters. In hindsight I should have just got new rear's as well. I couldn't locate a spring shop locally that would do anything but try to get me to order new springs from them,... at a lot more than I could buy them myself.
Old 01-31-2009, 09:18 PM
4tl8ford's Avatar
4tl8ford 4tl8ford is online now
4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold
JC Whitney is the best deal.
My local frame shop pays more from the same maker than what Whitney charges.
The owner of the shop is a friend - when I ask him what he could get me springs for he showed me an invoice.
Old 01-31-2009, 09:19 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Unless your old springs are cracked, a simple disassembly, cleaning, and re-arching should be all you need. Any decent spring shop can do it.
Old 02-01-2009, 07:47 PM
52 panel's Avatar
F-1 panel Rear Springs
I have 3 cracked springs on the left side, 2 on the right. It looks to me that replacement is going to be the way to go. Thanks of r the response.
Old 02-01-2009, 07:50 PM
52 panel's Avatar
I have not found a spring shop locally but will be looking. JC Whitney sounds like a good possibility.
Old 02-01-2009, 07:53 PM
52 panel's Avatar
Quote:
Thanks. I did a quick on line look at JC Whitney last night but didn't find see any but will do more research. Thanks for the tip. I have ordered the shackle kit from Dennis Carpenters ($60 for both sides.)
Old 02-01-2009, 08:18 PM
Try this link for JC Whitneyhttp://www.jcwhitney.com/webapp/wcs/stores/servlet/VehicleBrowse?tmplframe=VehicleBrowse&storeId=1010 1&showCustom=0&N=111%2B1952%2B200005338&catalogId= 10614
They where best price and with the bushings already in and U.S made you got to go with them. Mid Fifty sells individual leafs but I couldn't get any where with them since I was early 50's. They hooked me up with thier supplier but I couldn't make the $$$ work to justify the effort of rebuilding my old ones. Also,...if you can, try to catch the FREE SHIPPING SPECIALS Whitney has a lot. Look over thier page for it. They almost allways offer it. I hear its not a good idea to re-use the U bolts,....if you want to add them to the DC order.
Old 02-01-2009, 08:37 PM
Cant seem to get that J C Whitney link right
Old 02-01-2009, 09:14 PM
gearhead1952's Avatar
gearhead1952 gearhead1952 is offline
gearhead1952 is gaining momentum as a positive member of FTE.
Love your dark blue panel.
I put posies springs on the back of my panel which if I remember right was cheaper than going back to stock. Mine are the slightly lowered versions but with the taller housing of the 9 inch is probably pretty close to stock height.
Old 02-01-2009, 10:27 PM
52 panel's Avatar
tried the link. Can't get it to work, either. I did find front springs on JC Whitney. I've gone to tubular control arms and coil overs up front. Are the demensions the same front and rear? I would doubt it.
Old 02-01-2009, 10:34 PM
52 panel's Avatar
Thanks. I can't take credit for it. I bought this truck in 2004 and it was already painted, about a 15 year old paint job now. Still looks pretty good, especially if you stand back 10 feet.
I have an 8 inch out of a 69 mustang with stock rear springs. I have had a slight vibration since I have had the truck. It appears that I have a slightly warped axle flange which may have lead to the spring failure. Three cracked leafs on the side with the warped flange.
Old 02-01-2009, 10:45 PM
ALBUQ F-1's Avatar
postin' fool
If the Mustang axle didn't have the perches spaced correctly, that may have cracked the springs.
The JCWhitney springs are made by Eaton; any spring shop can order them. When I was in for mine, I looked thru the catalog and it was comprehensive.
Old 02-01-2009, 11:05 PM
52 panel's Avatar
Thanks for the input. I drive the truck pretty hard, about 12,000 miles a year in support of my real estate business. The road construction projects can be hard on things as well. The 302 dynos at 306 hp which is significantly stronger than the original flat head. All things added up, things break.
I will check with a speed shop I do business with tomorrow. I'm sure they have a spring shop in mind for their race customers.
panel truck fuel tank tinman52 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 08-05-2014 12:43 AM
Panel Truck Rear Door stops idtoy 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 11-04-2012 01:00 AM
Universal joints ...pinion angles 52 panel 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 02-15-2011 02:54 PM
1948-50 Rear Fenders and Box dick1950 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 01-03-2008 09:37 PM
Spare Tire Holder for 52 Panel 52 panel 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 11-13-2006 03:23 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
