Transmission Solenoid body 5r110 torqshift - Ford Truck Enthusiasts Forums
Old 01-31-2009, 05:08 PM
hacksaw830 hacksaw830 is offline
hacksaw830 is starting off with a positive reputation.
Hi,
Ive got a bad solenoid body and I have a doner tranny that has a cracked body but aleged good solenoid body, But when I removed the solenoid body, a star shaped washer looking object fell out, its about the size of a nickle and the prongs of the star are folded opposite of each other. Can any of you tranny mechanics help me out with a diagram or tell me where it goes? It looks like it possibly goes into the tranny body, there are three holes two of which have a 12mm nut in them the third does not it just has a couple of holes is this correct or not.
Old 01-31-2009, 07:16 PM
Nevermind I found out where it goes.
Old 12-31-2014, 09:07 AM
davepaque davepaque is offline
davepaque is starting off with a positive reputation.
Quote:
The same thing just happened to me. Where does that washer go? Thanks.
Old 02-15-2015, 08:59 AM
gdkerr gdkerr is offline
gdkerr is starting off with a positive reputation.
Coud either of you provide guidance on what the star shape disc is? I have the same problem.
Old 02-15-2015, 06:58 PM
Yahiko's Avatar
Yahiko Yahiko is offline
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
That is a flow restrictor. At some point they
switched to a bolt that has an orifice and no
washer thing.
What are you using to align the valve body when you reinstall it?
Sean
EPC solenoid replacement BigRedTed 6.0L Power Stroke Diesel 0 02-22-2016 01:15 PM
Solenoid Valve Body dsaldivar Clutch, Transmission, Differential, Axle & Transfer Case 3 09-25-2015 08:21 AM
EGR Vacuum Hoses 94Bronco2215 1978 - 1996 Big Bronco 8 07-28-2015 08:35 PM
T-85N Overdrive Solenoid gets transmission oil inside it... Solution? farmallmta 1967 - 1972 F-100 & Larger F-Series Trucks 5 03-23-2015 09:10 PM
P1746 Transmission DTC Zack Pandolfo 1999 to 2016 Super Duty 3 03-08-2015 10:08 PM
Tags
2005, 5r110, body, diagram, ford, location, locations, position, remove, replacement, seloniod, solenoid, torqshift, torqueshift, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
